Old 08-09-2007, 05:15 PM   #1
70GMCer
70GMCer's Avatar
Exhaust ?
Is the 73/84 exhaust system the same as 67/72 ? Will it fit ?
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 08-09-2007, 10:02 PM   #2
see ten
WTB this ad
see ten's Avatar
Re: Exhaust ?
I had a 71 gmc once that had the exhaust from a 67 Impala under it. Who knows! I would think a coil spring truck would be a lot different from a leaf truck. I would have to vote for doubtful but I don't know how resourceful or determined you are.
see ten is offline   Reply With Quote
Old 08-09-2007, 10:40 PM   #3
wibilly
wibilly's Avatar
Re: Exhaust ?
even if they are both leaf sprung you will have clearance isues with one rear shockbecause 73 and newer have stagered shock mounts. another isue will be at the manifolds. you may get it on but i don't think it will fit properly without some cutting and welding
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 08-10-2007, 07:55 AM   #4
70GMCer
70GMCer's Avatar
Re: Exhaust ?
Never mind the manifolds, I would be using headers. It's just that I always seem to be seeing a lot of exhaust kits for 73 up at decent prices. That's why I'm asking....
1997 GMC Sierra Ext
1965 Mustang
Old 08-10-2007, 12:42 PM   #5
70c10
67-72 Addict!
70c10's Avatar
Re: Exhaust ?
Run the pipe yourself to the mufflers to save some money and have a local shop mandrel bend over the axle unless you go with the LMC kit others here have liked.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 08-10-2007, 01:13 PM   #6
70GMCer
70GMCer's Avatar
Re: Exhaust ?
Knew that, but I had a line on a new exhaust system for those year trucks. I know about the LMC one. Thanks, Jim.....
1997 GMC Sierra Ext
1965 Mustang
