Old 10-26-2007, 02:26 PM   #1
chev74
Addicted to Chevy
chev74's Avatar
TPI setup
For $200 would this be a pain in the A$$ to put on my engine? would i need a standalone computer system?
http://dallas.craigslist.org/pts/457291040.html
chev74 is offline   Reply With Quote
Old 10-26-2007, 02:30 PM   #2
Pyrotechnic
Pyrotechnic's Avatar
Re: TPI setup
It would be an involved swap, but the end result would be quite nice. I'm sure you would see an improvement in gas mileage. You can use the stock computer and wiring. The only other thing I would do is order a flat tappet EFI friendly cam that will work with the stock TPI setup so you make the most of the stock computer tuning. I believe you also need the TPI specific distributor but I'm not sure.
Pyrotechnic is offline   Reply With Quote
Old 10-26-2007, 02:31 PM   #3
C&C Chevy
C&C Chevy's Avatar
Re: TPI setup
Easier if he had the wiring harness, and those can be pricey too.
Robert
Current:
1986 SWB Silverado 4.3 / TH400
Past:
1985 SWB Silverado 305 / TH350 - sold 1995
1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007
C&C Chevy is offline   Reply With Quote
Old 10-26-2007, 03:06 PM   #4
chev74
Addicted to Chevy
chev74's Avatar
Re: TPI setup
i have a cam that is a little stronger than stock- im not sure the exact specs, they are on the box back at my parents' house. good enough?
Old 10-26-2007, 07:29 PM   #5
Pyrotechnic
Re: TPI setup
I'm not sure of the exact differences but it seems like carbureted and EFI cams are different as far as vacuum signal. I know some people have swapped EFI setups on without even changing the cam and had it work ok, which make sense since GM EFI setups are extremely flexible to begin with. If it's just a slightly above stock cam with a strong vacuum signal, you could probably get away, especially with a mass air flow TPI setup, but there's no guarantee you won't need tuning or will get gas mileage like a stock TPI motor would.
Old 10-26-2007, 07:35 PM   #6
chev74
Addicted to Chevy
chev74's Avatar
Re: TPI setup
well if anyone was interested in buying it in case i was not- go ahead. I dont really have the time to do a major overhaul like that. Please buy away in case you were hesitant and thinking i had dibs on it
Old 10-26-2007, 08:20 PM   #7
rfmaster
rfmaster's Avatar
Re: TPI setup
TPI system does not offer as good of low end torque that TBI system would offer. However, TPI with MAF allows a bit more flexibility for a performance engine - i.e. wild cam, high compression, etc.
Anything above RV or mild street cam with a free flowing exhaust would require tuning and burning PROM's for the ECM. Do not forget that EFI swap also requires a high pressure fuel pump (TBI = 13 PSI, while TPI 38 to 48 psi) and return lines.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 10-26-2007, 09:49 PM   #8
Russell
Professional Grade
Russell's Avatar
Re: TPI setup
I would not buy that setup -- You'll majorly get nickled and dimed to death with having to buy all the stuff it is missing.
If you want to go EFI, get a complete running donor vehicle and swap everything over from it
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
