I can't get the wipers on my truck to come on. When I turn on the switch (column mounted), I can hear the motor working and the wipers will move a little bit and then stop and start making a grinding sound. If I leave the switch on and get out and pull on the wiper arm a little bit, the blade will come all the way up and back down and then hang up again. Does this sound like a bad wiper motor or what? Any ideas? Thanks.
![]() 2012 Silverado LT 1500, 5.3, 6 speed auto '86 SWB C-10 Silverado |
In the Forgotten far North.
![]() Join Date: Jul 2007
Re: Question about wiper motors or switch???
Most common thing to go out on these old trucks is the wiper motor.
However you may want to remove the cowel coer and take a look at the linkage to make sure it's still all good and tight especially where the linkage mounts to the motor. if any of it's worked it's way loose then tihten it all up and check it out.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade Last edited by BLE 'BURBAN; 10-16-2007 at 07:48 PM. |
Robert Olson Transport
![]() Join Date: Oct 2002
could be the cog on the motor that has a stripped tooth or two too . pull the cowl and make sure it looks workable then go for the motor. you can disconnect the arm linkage and see if it works that way but it may need the load of the arms to fail
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
