Old 10-20-2007, 11:52 PM   #1
syncrov69
syncrov69's Avatar
Original 1969 350sbc specialist please!
Can this engine look like an original 1969 350 sbc block. I'd like to have your opinion before make road to check all number. Thank's
'71 Custom/10 Deluxe LWB
'71 Custom/30 Deluxe Dually
syncrov69 is offline   Reply With Quote
Old 10-20-2007, 11:58 PM   #2
1969k10stepside
Re: Original 1969 350sbc specialist please!
It could be--The 350 didnt change much year by year that is visible stuff..the bracketry and pulley system look like original 67-72 truck stuff though...Can't really know till you check the numbers.It could be original,may not be...need the numbers to know.
1969k10stepside is offline   Reply With Quote
Old 10-21-2007, 12:23 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
been a while since I've dinked around with the small blocks... but I am thinkin that is a 71/72 alt bracket. I remember the 69/70 ones having the arm bolt to the cradle.
Old 10-21-2007, 07:01 AM   #4
Blazer1970
Blazer1970's Avatar
Did they make a 2 barrel 350? Otherwise it looks correct to me. Maybe a 307?
Blazer1970 is offline   Reply With Quote
Old 10-21-2007, 07:41 AM   #5
uncle
Looks like a 307 if you look at the harmonic balancer. If it has a 350,it's normally on the option sheet in the glove box and will also have the emblems on the fenders.
uncle is offline   Reply With Quote
Old 10-21-2007, 08:47 AM   #6
syncrov69
syncrov69's Avatar
The truck is a C/30 with a 157" wheelbase but no 350 is listed on the spid sheet. Is it stock in this kind of truck? Other question, what is the size of the harmonic balancer center bolt to turn the engine and confirm that engine turn?
Old 10-21-2007, 10:30 AM   #7
67_C-30
I have a radical idea!
67_C-30's Avatar
The balancer on a 307 ith be 6 1/4" in diameter and about 1.25" thick. The balancer on the 350 with be 8" in diameter and about 2" thick.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 10-21-2007, 10:36 AM   #8
syncrov69
syncrov69's Avatar
And what is the size of the center bolt to turn crankshaft manually whit a wrenche and socket
Old 10-21-2007, 10:57 AM   #9
syncrov69
syncrov69's Avatar
I have check the engine after a car run and this is a 283 not a 350. Is it interesting?
Old 10-21-2007, 11:45 AM   #10
stllookn
Saving 1 truck at a time!
stllookn's Avatar
283's are great little motors. I have one in my '67 stepside and since the compression is excellent...I don't even want to mess with replacing it. Some day it will come out and get replace with a larger displacment motor but for now it is just fine.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 10-21-2007, 12:03 PM   #11
1969k10stepside
My 69 4wd did have a 350 2 barrel..the truck was all original
Old 10-21-2007, 12:11 PM   #12
67_C-30
67_C-30's Avatar
It could be a 283, but it has been changed. A 283 would have an oil filler on the front of the intake and valve covers w/o pcv and oil fill holes. Somebody would have had to put the intake and covers off a newer engine. Did you look at the casting numbers on the back of the block? That's really the only sure to know what is. The stamping numbers on the front are usually useless unless you know the casting numbers and date codes on the back of the block because GM reused stamped codes from year to year.
My trucks
