View Poll Results: What kind of rotors should I get?
Drilled and Slotted Rotors 21 58.33%
Plain Jane Rotors 15 41.67%
Voters: 36. You may not vote on this poll
Old 11-07-2007, 11:15 AM   #1
Ackattack
Ackattack's Avatar
Drilled and slotted rotors
I'm on the fence as to whether or not to get drilled and slotted rotors. For the rear I can get them for about $200, or I can get plain ones for about $80. I know that basically there is no performance advantage to them, but they add a little bling. I mean the truck is going to be primarily a show truck, and with 20" wheels, the rotors will be pretty visible. So what do you all think.
Ackattack is offline   Reply With Quote
Old 11-07-2007, 11:24 AM   #2
Ole Blue 68
Ole Blue 68's Avatar
Re: Drilled and slotted rotors
I voted for Plain Jane but whichever you choose to go with, make sure they're dipped if you're planning on showing the truck. You don't want some rusty a$$ rotors showing behind your dubs.
Ole Blue 68 is offline   Reply With Quote
Old 11-07-2007, 11:38 AM   #3
SkylineNXS
SkylineNXS's Avatar
Depending on how fast ur goin, there should be some performance enhancments in teh drilled and slotted rotors. During hard braking they will better disperse the heat reducing break fade adn shortening stopping distance....just my opinion, plus they look sweet, lol...
BRAD
2000 GMC Sierra EXT Cab Short 4x4, finally mine...
1966 C10 SWB Fleet, 250 I6, three on the tree....
Previously Owned....
1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4....
1972 Chevy LWB Fleet 350/350
EXTENDED CAB ALL THE WAY!
.._..~...-...._...____
.._..-...______|_|__\____
..-..~.|_(O)__|_|__|_(O)]
SkylineNXS is offline   Reply With Quote
Old 11-07-2007, 12:18 PM   #4
Frizzle Fry
Frizzle Fry's Avatar
I picked up the matching front/rear summit brand drilled/slotted rotors. When I was buying the caprice rears I figured I might as well make the front match. Haven't installed them yet... I think they fit the look with big wheels, but are definitely more show than go.
Frizzle Fry is offline   Reply With Quote
Old 11-07-2007, 12:25 PM   #5
betonj97
Upgraded brakes is never a bad thing......I purchased rotors from www.rotorspros.com and I spoke to Richard. Drop him an email and let him know Jose from Sacramento recommended you to him. He can get them cut to your choice. slotted and drilled, or slotted, or just drilled. They are zinc plated so you wont have rust issues. I have purchased all my rotors from him and have never had a problem, these things are awesome!
As far as performance, in the rain I have noticed a difference, they grab better. All and all you are giving your rotors longer life because the heat/gasses that build up are released through the drilled holes.
Here is a quick pic of just the front, couldn't get a pic of the rear but same idea.
betonj97 is offline   Reply With Quote
Old 11-07-2007, 01:16 PM   #6
SCOTI
SCOTI's Avatar
Of those posting that have drilled/slotted rotors, how many have done back-to-back comparison testing to verify their claims of better performance? Reduced heat? Longer rotor life?
I personally haven't done any testing so I can't say. I know drilled/slotted rotors are all the rage but high end cars are proving that the 'benefits' that have been claimed were not necessarily true.
There are lots of performance cars that have been swapping back to solid rotors because of stress cracks from the cross drilling. Only a few OE manufacturers have 'drilled' rotors that are actually made w/the holes in them vs. drilling them after manufacture.
My vote is use them if you want the look, but don't believe all the hype until you can test them for yourself. I'll stick w/up-graded larger-diameter solid (un-drilled/un-slotted) rotors w/better brake-pads for my rides.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-07-2007, 02:15 PM   #7
Ackattack
Ackattack's Avatar
from what I've read there isn't a performance advantage unless maybe if you're running on a road course. Otherwise they actually reduce the life the pads. But they do look cool.
I'm ready to buy the rear rotors, but I'm holding out on buying fronts, hoping that an afordable big brake kit comes out (thread in the suspension forum). So we'll see.
Old 11-07-2007, 03:11 PM   #8
jamis
F.A.S.T. president
jamis's Avatar
We tested them on police cruisers and they didn’t make a difference. In fact of all the venders that have claimed their stuff is better we have not found anything better then the OEM rotors and the matching ceramic pads.
There may be a specific advantage on some race courses and conditions but not on the street and not every aplication.
F.A.S.T. President and Founder
Fabricators for the Advancement of Sawsall Technology
"A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis"
jamis is offline   Reply With Quote
Old 11-07-2007, 04:19 PM   #9
67mater
67mater's Avatar
I'd stay clear of the drilled rotors as they do nothing but give you more potential for cracks. I went to slotted rotors on my honda and noticed no difference, except less fade under heaving braking.
time is inversely proportional to money; that's why it takes me so long
1967 K10
1967 Camaro
67mater is offline   Reply With Quote
Old 11-07-2007, 05:30 PM   #10
SkylineNXS
SkylineNXS's Avatar
Less fade under heavy braking is always a good thing, especially with a generally heavier truck. Brake fade can sometimes determine if ull crash or if ull stay clear. Of course its probably not enough that its worth the extra 120 bucks...meh, o well...
BRAD
Old 11-07-2007, 05:33 PM   #11
panhandler62
Java Mechanic
panhandler62's Avatar
For your purposes -- I voted for the slots because they look cool. You said it's for show so looks would seem to be the principal issue to me.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 11-07-2007, 06:09 PM   #12
72 cheyenne pdx
72 cheyenne pdx's Avatar
I don't know anything about brakes, except the obvious as they are intended to slow/stop a vehicle. I believe all the shows I have seen that upgraded the brakes, went with slotted and/or drilled rotors plus upgraded to a 4-piston/6-piston caliper. I think it's the better clamping that will make you slow/stop faster than the rotor itself. I believe the slotted/drilled rotors were only designed to dissapate the heat better.
Then again, what do I know?
Good luck with your choice.
72 cheyenne pdx is offline   Reply With Quote
Old 11-07-2007, 06:49 PM   #13
SCOTI
SCOTI's Avatar
Define heavy braking. I doubt one would see the benefits of drilled/slotted rotors in a single panic stop which is what 90% of our trucks will experience. This is where ABS, larger diameter rotors, larger/stiffer calipers, & better pads come into play.
If it's a heavy truck hauling a trailer on a decline, I'd guess you won't generate enough airflow over the rotors drilled holes to affect cooling significantly. But, with the material removed from the rotors surface, there's not as much friction material in contact & that friction aids stopping.
If you replace the 12" x 1.25" HD truck rotor w/another that's been drilled/slotted & everything else remains constant, the truck might look better (purely subjective) . . .... but it prob won't stop any better.
This being said, it's your truck.... do whatever works for ya' .
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-07-2007, 07:28 PM   #14
N2TRUX
Happy to be here
N2TRUX's Avatar
The reality is that drilled and/or slotted rotors are just for looks on our trucks, nothing more. Just to clear up some myths, cross drilling is designed to help cool the rotor. Slotting is to help remove trapped gas from under the pad. If you do this to a stock size rotor, you might have a cooler rotor, and less fade due to the slots removing trapped gas, but you also have less surface area. That means that the gains are going to be minimal.
Does it look cool? Yes! Will I do it to mine? Well of course.
One thing to consider is drilled rotors will cause a brake lathe to chatter if it uses a conventional cutting bit that has a pointed tip. If the cutting bit has a rounded tip, the lathe has less potential to chatter. Because of the problems with bit chatter, some shops WILL NOT turn drilled rotors.
While it doesn't look as cool by itself, slotted rotors are much more effective. They remove the trapped gas allowing the pad to make full contact with the rotor. Since the slots are normally not cut clear through, there is little chance that the slots will cause stress cracks.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-07-2007, 08:13 PM   #15
68 P.O.S.
I've not heard of any valuable performance for daily driving with drilled/slotted rotors either. Since it's mostly for show, why wouldn't you??? Has anyone seen that they came out with drilled drums as well. I wonder if those will have any real affect on daily driving?
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 11-07-2007, 08:26 PM   #16
wibilly
wibilly's Avatar
why would you spend all that money on 20"rims and rubber without thinking twice about it and then question an extra $120 upgrading the brakes and also getting the look you want?
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 11-07-2007, 09:03 PM   #17
jorgensensc
jorgensensc's Avatar
Little info I recieved recently. We are upgrading to stainless lines, EBC YellowStuff brake Pads and EBC slotted and DIMPLED rotors (great motorcycle pads that now make automobile pads) For our Trailblazer SS. After talking with EBC they stated they are going to dimpled rotors instead of drilled through because of the stress crack issue. They then told me it was meerly asthetics at that point since the dimples were acting the same as the slots (since they are not drilled all the way through). My personal opinion is that if it is a show truck then go all the way drilled and slotted, it won't see much street time, so what does it really matter.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 11-07-2007, 10:30 PM   #18
Ackattack
Ackattack's Avatar
You're right, I'm not really concerned about the price that much. I was just wondering what people's opinions of them were. No since of spending extra dough if people don't like them. Since the "voting" is about 50/50, I think I'll go ahead and get them.
Old 11-07-2007, 10:40 PM   #19
kenm78
Broken Down
kenm78's Avatar
No matter what you choose brakes are only as good as they can dissipate heat! If you want more stopping power, and you said you are going with 20 inch rims go with oversized rotors
kenm78
1982 Chevy 4X4
Project truck
“It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt”
kenm78 is offline   Reply With Quote
Old 11-07-2007, 10:41 PM   #20
724x4a/cchevy
Self-proclaimed LED man
724x4a/cchevy's Avatar
I say go for it. They will compliment your big wheels nicely.
Justin
My LED Website
My Photobucket Album of LED's
Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK
I also do LED:
-Third Brake/Cargo
-Brake (truck and burb)
-Reverse (truck and burb)
-67-68 Front Turn Signals
-69-70 Front Turn Signals
-71-72 Front Turn Signals
-GMC Front Turn Signals
I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once
Norwood Survivor
724x4a/cchevy is offline   Reply With Quote
Old 11-07-2007, 10:45 PM   #21
custom72c20
custom72c20's Avatar
If I was you, I wouldn't cross drill and slot my rotors. I would just cross drill them because with both, you will make the rotor weaker and if you are not going to be doing any extreme braking such as in racing, so it really isn't needed. If you are going for the look, just do one or the other, so you lower the risk of the rotor cracking. It was originally only used on racing and high performance applications to allow gasses between the rotor and pad to escape due to the friction and help them with cooling. I know this because my dad used to cross drill and gas slot rotors for a living. I still have all the patterns he made (around 350).
Nick
Old pic of my 72: http://img340.imageshack.us/my.php?image=img0435co5.jpg
04 Silverado Daily Driver
68 GMC short step http://67-72chevytrucks.com/vboard/s...d.php?t=379665
"I'll beat you to the gas station!!"
custom72c20 is offline   Reply With Quote
Old 11-07-2007, 11:46 PM   #22
SCOTI
SCOTI's Avatar
Originally Posted by custom72c20 View Post
....It was originally only used on racing and high performance applications to allow gasses between the rotor and pad to escape due to the friction and help them with cooling. I know this because my dad used to cross drill and gas slot rotors for a living. I still have all the patterns he made (around 350).
To get a time-frame 'trend' on this modification, how long ago was 'used to'?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-08-2007, 12:34 AM   #23
custom72c20
My dad started doing it in the early 80's for a man named Dick Troutman who built porsche race cars and built Jim Hall's Chaparral race car. My dad did it all the way up until he passed away in 2002.
Nick
Old 11-08-2007, 01:34 AM   #24
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Most of what we do to our trucks I think is for looks being that they are street driven. This goes for most of the modifications we as owners make, but the performance claims don't hurt when it comes to selling parts or buying them, sorta justifies the whole thang if you know what I mean. If there is extra money in the budget go for it, for the rest of us who have a little tighter budget take heart in the fact that those who can afford it will never use the added performance that is claimed on most of these part mod's and we just saved a whole pile of dough!
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 11-08-2007, 11:51 AM   #25
Musclerodz
Race cars have not used drilled rotors for a awhile now. They are more prone to cracking. They will slot them to vent the gasses still. Holes are for bling only and if you can get solid in the same size as drilled, stick with solid. I know there is some rotors sizes with some brake companies you have no choice but drilled and slotted.
Mike
Mike Redpath
Musclerodz is offline   Reply With Quote
