Old 11-19-2007, 06:56 PM   #1
65 on 24's
65 on 24's's Avatar
67 prob
ok im workin on my dads 67 c-10 2 wheel drive . im pulled out the straight 6 and im puttin a 350 in. well he is keepin the 3 on the tree well he has a set of flow teck long tube headers on it . what is every one doing a about the clutch linkage in the way of the headers. how are yall hookin the linkage to the block
ridin big yo
5in cpp lowerin springs in back
lowered 3in in front with cut springs for now
5 lug swap and disk in front
5 lug and disk in the rear with 3.23 gears
mild 350/400heads
7547weiand intake
600 Edelbrock
chrome block hugger headers
2 1/2 pipes in to a x pipes
super 40 flows and turn downs
turbo 350 with shift kit
65 on 24's is offline   Reply With Quote
Old 11-20-2007, 12:46 AM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: 67 prob
bump
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 11-20-2007, 02:35 AM   #3
65 on 24's
65 on 24's's Avatar
Re: 67 prob
Originally Posted by dave2953 View Post
bump
and what dose taht mean
ridin big yo
mild 350/400heads
7547weiand intake
600 Edelbrock
Old 11-20-2007, 02:42 AM   #4
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Re: 67 prob
How is it in the way? On the '72 I used to own, I took the z-bar off, cut the lower bar off and altered the bend and rewelded it in a differant location (slightly inward). You may have to change to some shorty blockhugger headers if you cant alter the z-bar.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
http://67-72chevytrucks.com/vboard/payments.php
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 11-20-2007, 08:41 AM   #5
Re: 67 prob
Some headers clear,some don`t.3/4 length run right into it,can`t use at all.Is it the tube or just the lower arn in the way?I`ve cut the lower arm and re-welded out of the way.I`ve seen others where you can move the mount on the frame a bit.That`s a ball socker on the block end and the frame end pivots,too.You can run a bit of an angle with no binding.Are you mounting the V8 in the I6 position or the forward V8 position?I move the motor mount towers to the V8 position and get a longer driveshaft made.Keeps the motor out of the cowl,too.There are different brackets (factory) that offset the z-bar mount on the block according to what configuration the truck had.The V8 and I6 shifter linkage is different lengths.
Old 11-20-2007, 01:00 PM   #6
dave2953
dave2953's Avatar
Re: 67 prob
"Bump" is the same as ttt, or to the top. I relocates your thread back to the top of the forum in the hope that it generates more replies.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
