Old 11-15-2007, 01:02 AM   #1
63_C10
Engine questions
Hello everyone. I've got a 230 inline 6 and have been looking for sites that sell performance parts. I have not had much luck finding much though. Would I be better off swapping for a 292? Thanks!
63_C10 is offline   Reply With Quote
Old 11-15-2007, 07:10 AM   #2
Tim64
Tim64's Avatar
Re: Engine questions
Hi,
Try this link (if it works) lots of good info on inline engines.
www.inliners.org
Tim64 is offline   Reply With Quote
Old 11-15-2007, 11:31 AM   #3
baddawg65
baddawg65's Avatar
Try the link listed Below L6 performance
baddawg65 is offline   Reply With Quote
Old 11-15-2007, 08:09 PM   #4
wild one
Registered.........
wild one's Avatar
Another good site to check out http://www.cliffordperformance.net/ they cater to most I6 makes and displacements.
1966 C10 panel-400 small block/TH 350 combo
Nothing is fool proof to a talented fool!
Popcorn:
Pops at exactly 444 degreese
Expands to 44 times it's original size
Has a 4 year shelf life
wild one is offline   Reply With Quote
Old 11-16-2007, 04:35 PM   #5
Fred T
Cantankerous Geezer
Fred T's Avatar
Myself, I would get either a 250 or 292 to build. The 292 has a longer stroke and taller deck. But they are also a little harder to find parts for, especially brackets for AC and PS. The advantage of the 250 is there were many more made and they will drop right in where the 230 is.
The 230 was a decent engine, but will take more work to make it like a 250. I look at it as starting with something better and having a running truck while you're working.
Another site is www.stoveboltengineco.com . And an excellent book on building these engines is Chevrolet Inline Six-Cylinder Power Manual by Leo Santucci, available thru the on-line stores and www.inliners.org
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 11-17-2007, 12:15 AM   #6
63_C10
thank you all for your help. i will look into it and decide what i want to do. thanks again!
Old 11-17-2007, 09:48 AM   #7
Lane
What size do I have? lol
Lane is offline   Reply With Quote
Old 11-17-2007, 10:29 AM   #8
283 Man
283 Man's Avatar
looks like 250 6cly. could also be 235 6cly..the one in picture.
283 Man is offline   Reply With Quote
Old 11-17-2007, 03:03 PM   #9
Tim64
Tim64's Avatar
What is the easiest way to tell what ci engine you have? I think mine is a 230, but I'm really not sure.
Old 11-17-2007, 05:58 PM   #10
slow66
slow66's Avatar
The easiest way is check the casting numbers. The Inliners site that Fred T mentioned has a list of them and their displacements.
http://www.inliners.org/casting/numbers.html Good luck
Jason
slow66 is offline   Reply With Quote
Old 11-17-2007, 06:51 PM   #11
Fred T
Cantankerous Geezer
Fred T's Avatar
Looks to me like it's short.
Fred
Old 11-17-2007, 07:53 PM   #12
NF65Fleetside
NF65Fleetside's Avatar
Take your time and build it up with some nice Offy hop-up parts and chrome accents...I6's can spin the wheels and be pretty fun!
NF65Fleetside is offline   Reply With Quote
Old 11-17-2007, 11:36 PM   #13
Lane
True...
But it won't be long before this goes in:
Old 11-21-2007, 08:43 PM   #14
Tim64
Tim64's Avatar
Hey Guys,
I did some checking on my casting #s and come to find out my 1963 truck has a 1975 250ci engine in it instead of the 230 I thought it had. Guess that's what I get for thinking. I'm not sure if that's a good thing, or a bad thing. What do you guys think?
Thanks,
Old 11-21-2007, 08:50 PM   #15
rickf
rickf's Avatar
It's sort of an indifferent thing. If you are a collector going for factory stock OEM restoration, then you'd want the original engine, so the 250 is a bad thing. If you just want to drive it, the 250 is a terrific engine. The 250 and 230 are nearly identical, many parts interchange. The 250 just has a wee more stroke. As they say, no replacement for displacement, I'd be happy with the 20 extra cubes.
rickf is offline   Reply With Quote
Old 11-22-2007, 05:44 PM   #16
Fred T
Cantankerous Geezer
Fred T's Avatar
The 250 is a better engine. One problem with the 230 was piston failure. Dad had a piston replaced under warranty in his 64. I never heard if they had a bad batch of pistons or what. But he did lug the engine, which didnt' help.
On identifying your block, also check the casting date. It's located on the block, on the right side usually near the rear of the engine. It will be along with the conveyer line number. It will be in this format:
CON 2 C228
The conveyer number is meaningless for identifying the block. The dat is coded with month, date, last digit of year. C228 would be March 22 with a year of 68 or 78. Month is calendar order where A=Jan, B=Feb...
This helps if your casting # shows up with multiple applications.
Fred
Old 11-23-2007, 06:27 AM   #17
Tim64
Tim64's Avatar
Fred,
Yeah, my casting number shows years from 66'-84' but when you add in date numbers of CON 2 J275 it bought me to the 1975 conclusion. I think I'm de-coding it right. If not please let me know. Anyway I'm thinking I'm better off having the 250 even if it's a later model.
Thanks,
Old 11-25-2007, 03:44 AM   #18
rickf
rickf's Avatar
Do you have anything more than that one data point on the piston failure, any others' agree?
My own experience is a 1964 230 that went 250K-plus miles in 42 years(odometer broke in early 90's at 249K, definitely more miles on her than showing).
Engine still ran in 2006 when it was removed (I was given 350V8, couldn't resist.) Only repair on engine was valve job and hydraulic lifters replaced circa 1985.
Old 11-25-2007, 09:15 AM   #19
Lane
Um, where are the casting #'s?
Old 11-29-2007, 03:29 AM   #20
rwgregory
Lane, the casting numbers are on the right,(passenger side) of the block between the fuel pump and rear of engine, below the lifter covers and above the oil pan rail.
rwgregory
67 GMC 2500 ,2w/d wide box
305 V-6, 4-speed
rwgregory is offline   Reply With Quote
Old 11-29-2007, 09:55 AM   #21
Fred T
Cantankerous Geezer
Fred T's Avatar
Tim - J275 translates to Oct 27, probably 1975, but it could be 65. What is the casting #? I might have it in another listing.
Rickf - Just the word from the dealer who said that this wasn't the first one he had to repair.
Fred
Old 11-29-2007, 11:15 AM   #22
Tim64
Tim64's Avatar
Hey Fred,
The casting #366855.
Old 11-29-2007, 11:30 AM   #23
Lane
thanks!
