Old 08-03-2007, 11:11 PM   #1
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Get'n my GMC low
Ok girl-scouts, here it is
I want know what it would take to get my 67 GMC down low, like the fender being about 2 inches above the wheel
I'm thinking a flip in the rear & at least 3" spindles up front
But here is the catch, I need to haul my 4000 lb. trencher
I don't want to bag it, but helper bags are ok (right now it has over load springs, but I don't see how I could use them once I flip the rear)
This is just a rough idea of what I want it to look like
Any ideas or help is appreciated !
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 08-04-2007, 10:05 AM   #2
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: Get'n my GMC low
How much would I need to notch with a 4/6 drop ???
Sinister
Killer
Old 08-04-2007, 01:38 PM   #3
SCOTI
SCOTI's Avatar
None, unless you plan to carry a load.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 08-04-2007, 01:44 PM   #4
culookn
culookn's Avatar
if you slam it like that i would plan on having a crappy ride quality. plan on investing on a good set of drop shocks.
culookn is offline   Reply With Quote
Old 08-04-2007, 04:13 PM   #5
SCOTI
SCOTI's Avatar
If it's not engineered correctly..... sure. If done right, there's no reason it can't ride better than it did in stock condition & still be able to work like a truck should/can.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-04-2007, 07:47 PM   #6
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
So with flipping it & carrying a load, how much of a notch would I need... just a bolt in ???
Also, what would you do to try and keep it from dragging with a trailer on it... Helper bags ???
P.S. I understand the need for lower shocks or shock relocation
Sinister
Killer
Old 08-04-2007, 07:55 PM   #7
1LoC10
Insert Title Here
1LoC10's Avatar
2" Z, 3" spindles, 3" springs in front, 6" springs, 2" blocks, and a notch out back.. lower all the body mounts, and it should sit like that
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 08-04-2007, 08:00 PM   #8
SCOTI
SCOTI's Avatar
Yes. Bolt in would work fine @ the 6" drop height.
Yes. An air over leaf set-up would work.
Exactly. And I'm sure you realize this, but your photo-shopped pic is much more than a 6" drop.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-04-2007, 11:25 PM   #9
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Sweet
any particular brand you would like ???
I know, I just don't think that would be practical for haul'n
Sinister
Killer
Old 08-04-2007, 11:30 PM   #10
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
So up front would you use 3" drop spindles & a 1 or 2 inch spring
Also at 4 or 5 inches up front would I have any rub'n problems ??
Sinister
Killer
Old 08-05-2007, 12:13 AM   #11
SCOTI
SCOTI's Avatar
I would go spindles & cut 1 coil from the stock springs before I bought 'drop' springs.
Also a 4 or 5 inches up front would I have any rub'n problems ??
No problems if you keep tire sizing conservative. My 68 was 6" drop w/215-70/15's (26.85") on 6.5" wheels & I buzzed the tops of the inner fenderwells on 'big' dips only. Wider wheels w/more rubber or taller rubber will tend to interfere much sooner.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-05-2007, 10:03 AM   #12
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Thanks, about how much does cutting off one coil drop ?
So was that 6" up front & ??? out back, and did you use drop spindles & cut 2 coils off your springs ?
Where can I get a pic of your 68 ???
Sinister
Killer
Old 08-05-2007, 11:19 AM   #13
SCOTI
SCOTI's Avatar
Thanks, about how much does cutting off one coil drop ? So was that 6" up front & ???
Approx 2~3" of drop per coil removed (2" on newer springs & more on older springs that have some 'sag'. Yes, front drop was approx 6" (3" B.Tech spindles & 1 coil).
For the rear of my 68: Firestone bags, 1.5" lowering blocks, bolt-in c-notch, relocated shocks, adj panhard bar in stock location (approx 8" drop). I can't post pics from my work computer but I have @ least 1 pic somewhere on here already.
*edit.... home now*
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-05-2007, 02:31 PM   #14
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
So with a 6 / 8 drop, would I need more than a bolt in notch in the rear ???
Sinister
Killer
Old 08-05-2007, 03:07 PM   #15
SCOTI
SCOTI's Avatar
A bolt-in notch works. You'll also need to open a hole in the bedfloor for 'pumpkin' clearance @ 8" of drop (or raise the floor).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-05-2007, 09:57 PM   #16
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
So do you have any clearance problems with your 68, after all it is Texas
Sinister
Killer
Old 08-05-2007, 10:37 PM   #17
SCOTI
SCOTI's Avatar
No clearance problems after the pumpkin poked a hole in what was left of the original wood floor . It was driven daily before being parked for several 'up-grades' & has pulled my 18ft car hauler (loaded w/my 74) @ the height in the posted pic.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-05-2007, 10:59 PM   #18
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
So how many inches do you have between your rockers & the ground
I'm just trying to decide how low I can go without big problem with ground clearance, I think I can get by with a 6/6 drop
Sinister
Killer
Old 08-05-2007, 11:32 PM   #19
SCOTI
SCOTI's Avatar
I couldn't tell ya. If I could drive around daily w/a 6/8 drop, it stands to reason a 6/6 drop would work but would be kind of 'rakey'.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-06-2007, 10:43 AM   #20
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
I guess my truck is just different (or worn different), cuz it actually sits level right now & my running boards / rockers are about 12" off the ground
What did you haul with your truck & did you ever get off the pavement ???
Sinister
Killer
Old 08-06-2007, 03:24 PM   #21
SCOTI
SCOTI's Avatar
I've hauled several car's, a couple of trucks, landscape related stuff, & a household worth of furniture & appliances.
I've never had it 'off-road' so I can't help you there. I will say I don't think it's a good idea to have a truck this low & try to use it in the dirt.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-08-2007, 12:22 AM   #22
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Ok, new line of thought
What is the most drop you can get out of shackles ???
Cuz I could cut one coil off the front & use 3" shackles (if they are made) & should be plenty good for what Ima be do'n
Sinister
Killer
Old 08-08-2007, 12:52 AM   #23
SCOTI
SCOTI's Avatar
2" shackles is the most I've ever heard.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-28-2007, 04:17 PM   #24
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Ok, I'm thinking about this again lol
For the rear, if I don't don't flip it can I just move my spring mounts up ??? is there any problems in doing this ???
Sinister
Killer
Old 11-28-2007, 04:50 PM   #25
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
We moved the spring perches and shackle mounts on a '91 1 ton up a couple inches about 15 years ago. just popped out the rivets and drilled new holes and bolted the mounts back on. Not a lick of trouble. We did install a set of helper bags ( actually semi cab isolator bags since this was way before FS 2600's were cool )since the bed has a ton of weight in it. I'll try to post a pic if I can find one. same process should work on your truck.
Josh
P.S. Don't count out bags either my shop truck pulls a two car trailer with some heavy classic GM steel and it has been bagged ten years and has a stock floor body drop. Not one bag failure. never left me on the side of the road.
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
