Old 01-06-2008, 07:47 AM   #1
1970pelle
1970pelle's Avatar
Had exhaust installed today
Took the truck down to the local exhaust bender guy.Installed the 2 turbo II mufflers I had asked about last week.Ran the duals straight out the back.2 1/4 pipe.I knew the trucks cat convertor was plugged up and the old flowmaster had a broken baffle inside.What a improvement the truck doesn't labor at 35-45 mph.I'll mess with the carb adjustments when the weather get back to normal here.I did spot a small problem when on the rack.A coolant leak on the left side of engine.Most likely the freeze plug behind the starter.Guess what I'm doing tomorrow.Should I post a sound clip of the exhaust??
1970pelle is offline   Reply With Quote
