Radiator Overflow Tanks
I had to order a replacement overflow tank for my truck recently. I got the first one on and found out it leaked. Sent it back and got a replacement and it leaked also.
![]() 2012 Silverado LT 1500, 5.3, 6 speed auto '86 SWB C-10 Silverado |
Right turn Clyde
Re: Radiator Overflow Tanks
Not really sure how to seal it up. I have a 2 liter right now for an over flow bottle
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
Happy to be here
![]() Join Date: Mar 2000
Where did you order it from? I got one from LMC and it worked just fine.
maybe you are tightening the bolt too much?
Nobody rides free
![]() Join Date: May 2005
I got this stuff called "Seal-All" at the local NAPA. It says it will work on anything including gas tanks. I used it to hold my weatherstripping & it seems like top notch adhesive/sealer.
'71 C10 LWB 400SB/350TH ![]() '86 K2O LWB 350SB/400TH-6" tuff country lift, Shackle flip - plow truck '06 HHR - wifes wheels '01 Blazer - daily driver "It's better to burn out than it is to rust." -Neil Young |
I'll give LMC a try. Thanks.
On a budget like Fred Sanford
I picked a new one up from the stealership this summer and it didn't leak at all......guess I got lucky---now there's a change.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
Cruzzzn' Vet
BROTHERS didn't leak.
The overflow tank is thermoplastic, so is an ordinary plastic milk jug. I have used strips cut from a milk jug as 'filler rod' and a solder gun as a 'torch' to weld up holes and repair cracks before. Sounds
- Greg |
I found the leak on the old tank that was on the truck. It was at the base of the nipple. I found some of that "Seal All" bowtier was talking about (good stuff) and smeared all around it. That's all it took, no more leak. Thanks to you all.
Parts and more parts
I pitched my plastic one and installed an aluminum tank from an aftermarket supplier.
Do you remember who you got it from?
#13 | |
Addicted to Chevy
There are many different ones on the market. Look at Stylin Concepts for the ones that fit later model Chevy trucks. I put in the tanks for my windshield washer and radiator overflow that fit into a 88-98 Chevy pickup. They can be bolted right to the side of the fenderwells (Original mounting spots, but new mounting holes) and look real decent. There is also Summit racing, Jegs, Yogi's, and may other off-market suppliers on the web. There are tanks of all sizes. The one that I am going to put in my 68 Chevy C-10 is from "Be Cool" radiators and it is of a decent size.
#15 | |
Nobody rides free
