Old 12-06-2007, 04:31 PM   #1
robs72chevy
robs72chevy's Avatar
Unhappy h
have replace all fuel related problems when you let go of the key it cuts out. change the key assembly and the switch . im at a loss
robs72chevy is offline   Reply With Quote
Old 12-06-2007, 05:03 PM   #2
Re: h
What engine & type of ignition (stock or HEI, or ?)? Also is this a new problem or you just trying to get the truck going again?
Any wiring been messed with?
Hard to go on the little bit you provided.
Welcome to the board!
Old 12-06-2007, 05:04 PM   #3
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: h
yes, need more info
LOW DOUGH is offline   Reply With Quote
Old 12-06-2007, 05:48 PM   #4
dirtyd_nd
Re: h
Sounds like the ignition is wired up wrong/broken wire. If you turn the key to run, not start, does the radio come on?
dirtyd_nd is offline   Reply With Quote
Old 12-06-2007, 06:27 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: h
I agree that we need more info... But I am thinking (if stock) the resistance wire that goes to the coil... the one with the cloth covering... is burned/pinched/damaged.
When you are cranking the engine over, with the key in crank position, the coil gets power from the starter in the yellow wire that is on the coil. As soon as you let go of the key, the yellow wire no longer has any power, and it runs off that resistor wore I mentioned (at a reduced voltage level).
