Front drive shaft!!
Aight this weekend i put a 6in procomp lift on my 79 ling bed. i totally forgot about the front drive shaft going to be tooo short. so what do u guys think that i can do. this is my first full size truck, im still learning yet!!!
1979 Chevy Custom Deluxe (Ole Blue), built 350, Edelbeock carb, Hooker headers, dual glass packs, 2 in lift wit 32in Bfg a/t's on mickey tompson classic II's. - -Certified Welder-
Re: Front drive shaft!!
How much spline is left in the slip yoke??? If it's less than half...which it probably is...you'll need to hit the junk yards for a longer model, and cut/weld it to size. Your shorter one can be sent to me!!!
![]() A......
69' 3/4 4X4 470ci BBC 700 HP.... ![]() D60/14bolt 205/465 http://profile.myspace.com/index.cfm...ndid=127691959 |
I put a 6 inch lift on a blazer and have had no front drive shaft issues at all. I wheel the heck out of it and not one problem. You could also look into dropping your crossmember that could be enough.
Same here..4" lift should be fine with stock drive shaft.With a 6" lift the stock driveshaft should work,but it may not extend out that much.Having the stock one lengthened shouldn't cost that much.I don't know what models interchange that have a longer front driveshaft..
well looks like im going to cut it and weld it up at work and have the machine shop turn it back down.
I would still take it to a driveline shop and have it balanced. It doesn't take much to cause a vibration, which at the very least is hard on seals/bearings.
I had rear driveshaft shortened, balanced and new U-joints installed and it was only $115.00. They sprayed some kind if stuff looks like a bunch of bumps on it to get it balanced right. They also welded wieghts on(or kept original) to balance.
Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
Or how bout i found the front drive shaft off of my first gen s10 blazer i bought for parts a year or so back. Its the same damn thing, universals are the same just 4 inches longer!!
