Old 01-11-2008, 07:58 AM   #1
acl
acl's Avatar
gas gauge quick test.
Gas gauge not working in 68 chvy with 327. Is there a quick way to tell if its the gauge or in the tank. I have read lots of other threads about testing this and that. Not sure what volts or ohms I am looking for. A test light I can handle. Barely.
Gary
The gauge is stuck on empty
THanks again
acl is offline   Reply With Quote
Old 01-11-2008, 10:09 AM   #2
lbpd719
Zappaphile!
lbpd719's Avatar
Re: gas gauge quick test.
what is the gauge doing or not doing. Thats a good starting point.
Pull the wire off the sender at the tank.. if the tank goes all the way over past full, it's probably in your sending unit.
1969 C20 LWB Camper Special - The Beater..
1998 Cheyenne V6 - 4/6 Drop - For The Son
lbpd719 is offline   Reply With Quote
Old 01-11-2008, 11:23 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Then, with the egnition on, take that same wire and ground it to the body of the tank. If the guage drops to empty, then everything from the wire to the guage is fine, and the problem is in the tank.
If the guage doesn't react to either of these, then it's time to start troubleshooting more, but more times than not, I have found the wire to be corroded and green and cut underneath the chrome sill plate in the drivers door jamb.
Old 01-11-2008, 02:24 PM   #4
OJOE
Crew Cut
OJOE's Avatar
i thought, with switch on and wire at sending unit grounded the guage should show full
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 01-11-2008, 02:35 PM   #5
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
67-72 sending units run 0 to 90 ohms. 0 is empty and 90 is full. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 01-11-2008, 04:02 PM   #6
DavesRide
DavesRide's Avatar
At our shop we had a tool that was a set of different potentiometers (adjustable resistance device) that made it very easy to diagnose. Now knowing the resistance you might swing by Radio Shack and see if they have something close. Otherwise, you can replace both with known good units. You still may not fix it if a wire is broken inbetween.
In my past experience, 98.657% of the time it was the sending unit since it has moving parts that wear out but time is money and money =time, but guessing also equals time and money also.
This is just my other hobby idea. Got a slot car track? The hand controllers are potentiometers. Hook it up wires at tank that go to gauge and see if changes happen.
Also check the the wires for continuity between the sender and gauge.
R.I.P ESLL Even as the body dies the spirit lives on in the people you touched
DavesRide is offline   Reply With Quote
Old 01-11-2008, 04:12 PM   #7
haysonj
haysonj's Avatar
I just got a new sending unit from LMC and would not work. Had to drop the tank to check it and it was a bad solder joint and the float filled with gas
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 01-12-2008, 12:04 PM   #8
tjvending
tjvending's Avatar
Does the float come out when you pull the sending unit?
TJ
tjvending is offline   Reply With Quote
Old 01-12-2008, 03:53 PM   #9
haysonj
haysonj's Avatar
yes its all one piece the suction pipe filter screen float and reostat
