67-72 Addicted
Control Arms?
Are 1971 2wd 1/2t control arms the same as 1970 2wd 3/4t? what the diference? can the ball joints just be switched?
Dave's not here, man
Re: Control Arms?
I think the arms are different, but that the balljoint diameter is the same. The threaded parts of the balljoint may be different lengths, though. Others should chime in with more info.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
Hand Crafted C-10
![]() Join Date: Aug 2006
Re: Control Arms?
I need to know how they are different also. I've got a FE from a 1970 or 1971 that I need to buy parts for. Wondering if the pivot arms are the same, as well as the ball joints. Thanks dave2953 for starting this thread! ET
. Forum Guidelines and Rules
Buying and Selling Code of Conduct Become a Board Supporter! Truck FAQ Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member... |
Fabricate till you "puke"
Re: Control Arms?
you can swap the upper arms(just swap the ball joints). The lowers are different from 1/2 to 3/4 ton, due to the size of the hole in the arm for the ball joint. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
