![]() Join Date: Jul 2007
5 x 5 bolt pattern
Is there any way to change this to lets say 5 x 4.75"? a kit or hub rotor that fits?
STILL PLAYS WITH TRUX
There's allways a way!
Why would you want to? One way is you could get a set of adaptors but if you do don't be cheap buy a good billet aluminum set not cast. This way would be the easiest and fastest and cheapest way to go but not the smartest! Another way is to install a smaller set of spindles and brake rotors & calipers from a S10 but there would be some mod's needed to make them fit but it can be done and a rearend from a S10 or a car that run's a 5x4.75 BP but that kind of defets the purpose of having a truck. Another way would be to remove the stock rotors and axels from the truck and take them to a machine shop and have them drilled to the 5x4.75 BP. Im guessing you want to run a set of 5x4.75 wheels and they don't offer them in a 5x5 BP. Out of the three way i have given you i'd personally do none of them. The best thing that i can tell you is leave the truck in a 5x5 BP configuration and find another set of wheels that match it. Good luck. |
Happy to be here
![]() Join Date: Mar 2000
Re: 5 x 5 bolt pattern
What are you trying to accomplish?
Rim selection - and I'm going to build a Dana 60 and I'm having a hard time finding aftermarket discs with a 5 x 5 BP. - I can have the custom axles drilled to whatever I want - it's the brakes that worry me.
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
I'm rebuilding the rear in my '71 and because of my wheel selection I had to go with the 5x4.75 bolt patern on the new axels. New axels from Moser cost me a couple hundred bucks but they are strong. I'm going with disk on the back but I haven't got to the point that I need to make that selection yet.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() |
You could have the rotor drilled for the 5x5.
I can still count my vehicles on two... wait three hands. |
Why not go out to a 5 X 5.5? A bunch of factory & aftermarket rims to choose from.
I called Currie Enterprises, and they offer a 5 x 5bp rear disk set up - so I guess I'll compromise with the rims.
Alex,
You can get a rear end out of the junk yard from a 96-99 Impala the Taxi or Police version of the SS all came with rear disc and there a 5x5 BP. You can have you Dana 60 built using the Impala end flanges so everything will just bolt on. |
Wide n'Low
![]() Join Date: Jan 2007
Just another option, I had a custom Dana 60 built using big ford bearing ends, and this allowed me to choose virtually any wheel combo I wanted. I ended up using a rear disc setup from a 74 Lincoln which has 11 inch rear disc with a 5 on 5 pattern.. the Flange also has the parking brake cable mounts
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
Awesome! I love this site!
i've got one of those rear axles just waiting for a special occaision.
