Old 02-15-2008, 01:30 AM   #1
trebeck
trebeck's Avatar
Air Ride - Compressor and Tank Location Help
Could I get some pics/ideas on where some of you may be mounting your air ride components: solenoid block, tank, compressor.
Thanks in advance!
trebeck is offline   Reply With Quote
Old 02-15-2008, 04:21 AM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Air Ride - Compressor and Tank Location Help
I've seen them mounted in the following locations:
- installed in the back underneath the bed (spare tire area)
- along the frame just behind the cab
- in the cab (tank and compressor)
- in the bed
- under the hood (compressor)
It's an open slate... I recently saw a truck that had the tank towards the rear (spare tire area), along with the compressor, and had the valves mounted just behind the cab on the passenger's side. There was a truck at a car show 2 years ago that had everything mounted on the outside of the frame rails.
Check out this thread...
Good luck with the decision!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 02-15-2008, 06:19 AM   #3
shifty
Questionable
shifty's Avatar
http://67-72chevytrucks.com/vboard/s...54&postcount=5
http://67-72chevytrucks.com/vboard/s...58&postcount=6
http://67-72chevytrucks.com/vboard/s...9&postcount=11
http://67-72chevytrucks.com/vboard/s...&postcount=420
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 02-15-2008, 06:29 AM   #4
trebeck
trebeck's Avatar
Good stuff, thanks shifty. I believe I'll go the same route as rokcrln, both bolted to the right or left frame rail. Solenoid and ECU may go behind the seat (not sure yet). My fuel tank will be mounted in the rear of the truck, so that eliminates that setup...although the post by n2trux is pretty sweet.
Just a note, I'll be using Air Rides RidePro e2 kit (one 3gal tank).
Old 02-15-2008, 10:28 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
I suggest you get the compressor as far away from the cab as possible. No matter what brand you use, those suckers are LOUD!
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-16-2008, 12:44 AM   #6
trebeck
trebeck's Avatar
That answers my next question, thanks
