headlight adjusters
Are the adjusters the same on a 1965 GMC PU as those on '60-'61 Chevys? (dual headlights). Who sells replacements?
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Re: headlight adjusters
here are both kinds
http://classicparts.com/products.asp?dept=200
If all you need are the plastic inserts and screws you can get them at any parts store usually in the help section
Thanks fellows, just what I needed to know.
Make sure the square plastic insert will fit into the square opening in your headlight mounting bracket. I have bought them before, only to find out they were not the correct size. You can also secure your existing plastic inserts with epoxy, if you can't find the correct size or find a good set of used ones.
#6 | |
