Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 02-15-2008, 11:52 AM   #1
Wild83C10
Wild83C10's Avatar
Parts For Sale-headers-heads-cams-engines
I have the following parts for sale. All engine parts are used and for a Small Block Chevy.
1. Trick Flow heads-SOLD
2. '74 350 2-bolt long block. It needs a rebuild. Best Offer I can help with delivery if within a reasonable distance, just pay for gas.
3. '74 355 4-bolt short block assembly. Original 4-bolt block, cast crank and rods, forged pistons. Will include all new bearings. Needs to be assembled. I can help with delivery if within a reasonable distance, just pay for gas.
Machine Shop work:
cleaned
honed
new cam bearings
polished crank
new bearings
new rings
$750 or BO
4. Comp Cams Hydraulic Flat Tappet Cam w/ lifters and springs. Springs are matched to the cam. P/N for the cam is 12-254-3.
Specs: .519 intake lift, .523 exhaust lift, 294 intake duration, 306 exhaust duration at tappet lift. 250, 256 at .050 lift. 110 lobe separation. I have original box and cam card.
$275 or BO, plus shipping
5. Cammotion Hydraulic Roller Cam w/springs, NO lifters. Custom ground cam, Grind Number: X2371-24410-10.
Specs: .580 intake lift, .592 exhaust lift (w/1.6 rockers), 239 intake duration, 247 exhaust duration @ .050 lift. 110 lobe separation. I have original box and cam card.
$275 or BO, Plus shipping
6. Summit 2" Drop Springs. SOLD
7. Hedman Headers. Long Tube Headers for 73-86 Chevy C10 w/SBC. They are in good condition, with black header paint. I painted them before I used them and baked the paint on. The paint looks ok and it has kept the headers in good condition. They have a 3" Flowmaster ball flange collector on the end. The ball flange doesn't require a gasket and works great. I also have an O2 bung in each header (running aftermarket EFI). They are 1-5/8" primaries, no dents or dings. HEDMAN P/N 69090
$60 or BO
Please ask any questions. I will make a better deal if you buy multiple items.
Thanks, Joe
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
