Old 03-26-2008, 09:33 PM   #1
mateo1279
mateo1279's Avatar
62 vs 64 wiring
So... I was driving down the freeway and smoke started drifting out from under my dash. I pulled over, started pokein' around and found the connector for my headlight switch and the 'plug' of wires were very hot. I also saw the lights on my dash were out. I continued my trip w/o headlights and the smoking did not occur.
It seems the smoke is being caused by something attached to this circuit...
I have a wiring diagram for 64 a member supplied(thanks rodnok1), but am curious if it is interchangeable with my 62?
I did a search and found some good resources, including info on wiring a relay(which I think I will do), but none that answered this question.
Thanks!
-Matt
1962 Chevy Fleetside
283/TH350
mateo1279 is offline   Reply With Quote
Old 03-26-2008, 11:48 PM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: 62 vs 64 wiring
It might not be exactly the same due to the gauge setup, but the lighting circuit colors should be the same.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
