![]() Join Date: Apr 2007
Rocker Box Help!
Hey guys - I am working on the floor pan and Rocker boxes. Curious if anyone has any good pics of where the rocker boxes attach to the floor pan. I assume the boxes weld at the holes that line the box, but curious what it should look like.
Thanks |
Re: Rocker Box Help!
Outer rocker to inner rocker to torsion box is the assembly order.
(outside to in) We have a very useful tool here called the search function, works great when your searching for info you want asap, gives you all the threads pertaining to the subject title without the wait for someone to reply to a post. Found under 'torsion box' search title: http://67-72chevytrucks.com/vboard/s...earchid=754637 Post up some pics if your able so we can see exactly where your at with it and we'll be happy to help where we can. ![]() Last edited by vtblazer; 03-26-2008 at 02:39 PM. |
I tried those threads and others and did not see a pic from the underside. Here is the shot i need, but i need to know what they should look like...
![]() Join Date: May 2006
Can't quite see the area your looking for, LMK and I'll take pics...J.
If you have them off, I need the dimensions of the spce inside...
'72 K5, known as 'the Fox.' |
