Old 04-09-2008, 04:44 AM   #1
nhtc33d
Axle U bolt size
I need to get longer U bolts for the trailing arms I am making. Do you think that a 1/2" diameter bolt would be strong enough? Thanks for any help.
nhtc33d is offline   Reply With Quote
Old 04-09-2008, 05:10 AM   #2
shifty
Questionable
shifty's Avatar
Re: Axle U bolt size
someone else will know for sure, but i'm pretty sure the front control arms on the 67-68 pickusp use a 1/2" u-bolt to hold the control arms on and the 69+ use 9/16"...but it could be 9/16" on 67-68 and 5/8" on the 69+, respectively. those bolts are a lot shorter too. will be interested to see input - a lot of guys are all about "overkill", so ....
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 04-09-2008, 01:35 PM   #3
nhtc33d
Thanks for the reply Shifty, I think My stock U bolts on the front were 1/2" also(1965). Thats why I thought 1/2" for the rear would be ok?
Old 04-10-2008, 02:56 AM   #4
nhtc33d
Han anyone needed to buy longer U bolts for there rear axle? If so what diameter did you go with?
Old 04-11-2008, 04:08 AM   #5
mikeoj
They are 3/4.
69 Lwb C-10 402/700R4
70 Lwb C-10 250/3pd
Wisc.
mikeoj is offline   Reply With Quote
