Old 04-10-2008, 05:09 PM   #1
61hawk
61hawk's Avatar
Anybody do CNC Machining
I'm looking to have a custom bracket made up (flat aluminum) to hold a remote thermostat housing. I could do it myself with shop tools but think a CNC produced bracket would look better. I don't have the specs right now, I'm just trying to find out if anyone out there has access to someone who can do small CNC projects.
Lee
61hawk is offline   Reply With Quote
Old 04-10-2008, 07:18 PM   #2
Tim64
Tim64's Avatar
Re: Anybody do CNC Machining
Hey Lee,
I do CNC machining. Let me know what you need, and I'll see what I can do.
Tim64 is offline   Reply With Quote
Old 04-10-2008, 07:53 PM   #3
61hawk
61hawk's Avatar
Originally Posted by Tim64 View Post
Hey Lee,
Thanks Tim, this should be really easy, here's kind of what I am wanting to build. Mine won't be as tall, I'm going to run the lines under the intake manifold instead of over it and I'm hoping that if I used thicker aluminum that I could create more of a "bracket" than a "panel" to attach the thermostat housing to. It'll probably be a month or two before I'll need this, but maybe between the two of us we can come up with something simple that looks decent. I'll get back up with you once I can get some measurements.
Lee
Old 04-10-2008, 08:45 PM   #4
Tim64
Tim64's Avatar
Sounds cool, just let me know. I don't think I've ever seen anything quite like your example before. That is one sweet looking engine.
Old 04-10-2008, 11:12 PM   #5
61hawk
61hawk's Avatar
Thanks Tim, that's not mine, it's one a guy over on a hemi forum pointed me to. Mine is going to look more stock looking (cleaner).
Lee
Old 04-11-2008, 12:56 AM   #6
Fred T
Cantankerous Geezer
Fred T's Avatar
As high as that sits, you will be much better off to run stiffeners from the upper end down to the front bolts on the intake. As it is, I can see problems with the water pump bolts due the all the leverage (moment arm).
If you have holes in your head (I do ) you could use them. Having another attach point, either above or below will help a lot with reducing loads and vibration.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 04-11-2008, 03:11 AM   #7
61hawk
61hawk's Avatar
Thanks, I agree. That's not my engine... just a shot with what I'm wanting to do.... but lower and less "sheet metal" looking.
Lee
