Old 04-21-2008, 05:55 AM   #1
63Stepside
repacking rear gears
Greetings all. As you can tell from my user name I'm the proud owner of a 1963 Chevy Stepside. In a effort to extract the best possible gas mileage from my straight six I plan to install the most fuel efficent rear end set up. My question is: Can you pack 3.07 or 3.38 gears into a transfer case that once housed 4.11 gears? If so,It will cost $200 for a new ring and pinion and $300 to install. I would much rather go this route than buying a 40-45 year old complete rear end and installing it myself. If you can offer some advise please email me at andy_824@windstream.net (that's an underscore between andy and 824)
63Stepside is offline   Reply With Quote
Old 04-21-2008, 04:34 PM   #2
Fastrucken
Junior Member
Fastrucken's Avatar
Re: repacking rear gears
You will need a spacer that goes inbetween the carrier and the ring gear to place a 3 series gear on a 4 series carrier. other then that no issues. this is assuming you have the 12 bolt and not the eaton rear end.
Graham
A good friend will come bail you out of jail, but a true friend will be sitting next to you saying, "That was ****ing awesome."
Fastrucken is offline   Reply With Quote
Old 04-21-2008, 04:52 PM   #3
greg64
greg64's Avatar
Howdy from BC! Typically, the carriers that hold the ring and spider gears are capable of handling a certain range of ratios. This is to accommodate the differences in pinion gear diameter. What type of rear end do you have under your truck? I wouldn't be surprised if your 4.11 carrier can accommodate 3.07, but I'd want to check to be sure.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 04-21-2008, 04:56 PM   #4
billydonn
Council of the Elders
billydonn's Avatar
If it's a truck twelve bolt, the dividing line for the carrier change is 3.73, I believe. This is based on shopping I've done for new ring and pinion sets.
66 C-10 Stepside
350 Tuned Port Injection
Tremec TKO-600
Truck Pictures: http://community.webshots.com/user/billydonn
Truck Video: http://good-times.webshots.com/video...ost=good-times
billydonn is offline   Reply With Quote
Old 04-21-2008, 06:03 PM   #5
kdrodworks316
KOFFIN DRAGGER
kdrodworks316's Avatar
just my opinion, but why not update the whole rearend? maybe a 12 bolt or a dana 44 out of a 73-92? would require a little fab work, but should be cheaper and easier than rebuilding your existing one. not to mention the 44 would be stronger and have more gearing options.
kdrodworks316 is offline   Reply With Quote
