my brakes?????????
I started off changing my rear brake shoes and I proceeded to bleed brakes, no brakes still, I checked front shoes just fine, so I changed the master cylinder got a nice brake pedal when truck is off drove it and could not stop, as far as I can tell the brake booster seems to work fine no air sounds and not a really stiff pedal.I have visually check for leaks nothing that I can see any help would be greatly appreciated thanks.
#2 | |
Re: my brakes?????????
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-16-2009 at 10:42 PM. |
they were going down almost to the floor but it seemed as though none of the shoes were expanding out almost like no friction there.
Did you bleed the master cyl independently before installing it, connecting & bleeding the lines?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-16-2009 at 11:34 PM. |
It may sound crazy, but did you expand the shoes out to meet the drum after installing the new shoes?
Too many dreams, too little money. |
Yes we did bleed the master cylinder, but I will have to check and see if he (my father)adjusted the rear brakes.
