Old 11-03-2002, 06:38 PM   #1
CPNE
Resident Curmudgeon
CPNE's Avatar
Need expanation of dash harness diffs between 72 truck and 72 burb
Ignition wiring in my 72 burb shorted and detroyed switch and harness connector. I have a 72 truck harness to replace it with. Main question is rear light wiring. Trucks connect on the firewall and run along framerails. Burbs connect (i'm not sure where) and run up thru pillar and along driver side roof. What incompatibilities am I in for? Is it plug and play (brn, yellow lt green and dk green use same male connector as trucks), or would you suggest just spicing the ignition wires on existing harness to a new connector and use new switch?
FYI, burb is in CT and I'm in NH so I can't go look for myself right now, so please help.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
