WD40 is a great hood alignment tool!!
My hood looked pretty good. The margins were all nice and the back near the cowl was a little high,but I could live with it. My biggest problem was the rear of the hood hitting the cowl ever so slightly when I raised it. I adjusted this till I was blue in the face but could not get it to stop hitting. My hinges are in decent shape with very little wabble. So I decided to lube the hinges with WD40. Man!! I slammed the hood so hard the first time I shut it after spraying the hinges my headlights and grille fell on the ground(LOL). Not really but it was amazing how easy it opens and shuts now It is actually to low near the cowl now. And I closed the gap between the cowl and hood.
Re: WD40 is a great hood alignment tool!!
Lubrication is a beautiful thing.............
![]() But now that you have things "loosened" up, lube it with something better. WD-40 is more of a solvent than a lubricant. It will not last, it evaporates and you are right back where you were. White lithium grease (sprayable) will do what you need. Shoot some on your door hinges while you are at it. |
Project: years too late.
hmmm i shall keep this in mind aswell. thanks Longhair!
1971 C10 Stepper LSX 5.3/4L60E 3.73 12bolt posi. Father Son Project. In Memory of Bruce C. Shorten. Rest easy Dad. Ill take it fryom here. |
Friday's Toy
![]() Join Date: Nov 2006
Sprayable white lithium grease solves so many problems it's not even funny! Good stuff!
68 C10, SWB Fleetside with a 454, Turbo 400 and 4.11 posi....Exxon/Mobil loves me. 2009 Jeep Rubicon 2011 Powerstroke FX4 (totaled) 71 C10, SWB Fleet with factory tilt 72 LWB C10, 350 700R4 with factory tilt |
Back in the sticks
Hmm, I'll get some tomorrow and try it on mine. They are newly blasted and painted, but not lubed.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
#6 | |
Gone to greener pastures
![]() Join Date: May 2007
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
its all about the +6 inches
hood hinges are almost always forgotten. I would spray it and work the hood real good.... like spray a whole can on them, then follow it with some brake clean solvent, then once that dries, hit it with the white grease.
I am sure there are better lubes than WD40 but that is all I had at the time. I will do it next time with White lithium. It would probably stay alot longer. I couldn't belive how many pivot points and surfaces each hinge had.
