Old 06-04-2008, 10:46 PM   #1
Gene Sharp
47 ri 59 4x4
I have a question has anyone put 4x4 axels under a 47 to 59 Chevy truck
what did it involve and what steering box did you use to get good power steering
Gene Sharp
Gene Sharp is offline   Reply With Quote
Old 06-05-2008, 09:21 AM   #2
FormerMember
Re: 47 ri 59 4x4
Gene Sharp
Not factory.
Napco did a few conversions in the later model trucks.
Most people are swapping frames. I've seen those body styles on K5 frames, to convert to 4wd, get a stronger frame and power steering.
FormerMember is offline   Reply With Quote
Old 06-05-2008, 01:23 PM   #3
Gene Sharp
Re: 47 ri 59 4x4
I have two pickups with later model frames and 4x4
have a couple of others and wanting to try it a different way
Iknow the Napco trucks had 4x4 acels added
does anyone know or a good steeriing box to use
when using stock frame
Gene Sharp
Old 06-08-2008, 10:15 PM   #4
cobinder
Everything is work in progress
cobinder's Avatar
Re: 47 ri 59 4x4
Gene post a few pics and we can help you out better. If your wanting to convert to power steering you can throw a hydro-boost on there at the same time and have power brakes and steering, a major bonus.
Good luck with your truck!
How much?! It's just an old truck part!!
49 International on a 80 GMC 3/4ton 4x4 chassis
48 International KB-5 2 ton dump bed
04 Honda CRF "500"
09 Honda CRF450 fuel injected rocket
03 Suzuki hayabusa carbonfiber wheeled monster.
02 Ford diesel stretch van (toy hauler)
01 38' Monaco diesel pusher motorhome
cobinder is offline   Reply With Quote
Old 06-09-2008, 09:21 AM   #5
FormerMember
Re: 47 ri 59 4x4
I think CPP has a set of weld on plates for a normal Chevy style Saginaw steering box.
Old 06-09-2008, 01:16 PM   #6
Senator350
Senator350's Avatar
Re: 47 ri 59 4x4
Grendel, don't mean to hi-jack.. but is your username because of the 6.5 grendel cartridge?
my reccomendation would to (hopefully not being too obvious) use 1-ton axles. if you're serious about offroading it, i'd suggest high-steer arms.
the power steering box from 67+ 4X4 trucks should work fine for you if you have the correct place to put it (if your body mounts or other don't get in the way) and a steering box from a 2WD 67+ will work if you do use high-steer
mounting the steering box shouldn't be too much of a problem.
RN U OVR
Senator350 is offline   Reply With Quote
Old 06-09-2008, 01:19 PM   #7
FormerMember
Re: 47 ri 59 4x4
No, i've been using it far longer. I used to work with Beowulf Clusters years ago. I also was fond of the Epic and got tagged with it in high school.
I do agree, that considering you have to fab something up, I'd start off with at least cross over steering and stay away from a 4x4 push pull steering set up that Chevy loved so much.
