Old 06-28-2008, 06:21 PM   #1
COMP
Tie-rod ends etc. ??
who is making the best parts and why for a 77 2wd ????
COMP is offline   Reply With Quote
Old 06-28-2008, 07:01 PM   #2
79gmcsierragrande
Manual Transmission Club
79gmcsierragrande's Avatar
Re: Tie-rod ends etc. ??
I’ve been using Moog for years. I’ve done the front end with all Moog parts on two Toyotas and I’m in the process of replacing all chassis parts with Moog on my 2X4 79 Sierra right now. All their parts are high quality and last, I’ve never had to re-replace any of their parts.
79 GMC Sierra Grande, SWB, Heavy Half
If I wanted easy I would just buy a NEW truck!
79gmcsierragrande is offline   Reply With Quote
Old 06-28-2008, 07:04 PM   #3
GMBowtie79
Surviving, one day at a time!
GMBowtie79's Avatar
MOOG all the way!
79 Burb,350,tremic 5 spd, 4 wheel disc, daily driver
74 swb,350,350,driver & future project
"There's no such thing as a finished project"
GMBowtie79 is offline   Reply With Quote
Old 06-28-2008, 07:10 PM   #4
COMP
what about Spicer ??
Old 06-28-2008, 07:31 PM   #5
scotts62
One day...
scotts62's Avatar
too moog all the way! Ya spicer is good too
Scott
93 crew cab build
Project 62
Old 06-28-2008, 07:41 PM   #6
COMP
my MOOG parts are wearing out
Old 06-29-2008, 04:09 PM   #7
COMP
no other companys ????
Old 06-29-2008, 05:52 PM   #8
GMBowtie79
GMBowtie79's Avatar
Thats the only one I use for steering linkage and balljoints. As long as you keep them properly lubed the last a long time.
Old 06-29-2008, 10:03 PM   #9
COMP
4-6 times a year ,,, thats always worked ,,,,is some of the MOOG stuff made in China ??
Old 06-29-2008, 10:33 PM   #10
79gmcsierragrande
how many miles on them?
Old 06-29-2008, 10:47 PM   #11
COMP
30-32K
Old 06-29-2008, 10:53 PM   #12
scotts62
One day...
scotts62's Avatar
30-32K
Was that a hard 30-32K?
I would expect mine to wear out faster than usual way i treat them sometimes
But ya you would figure they would last longer..
Scott
93 crew cab build
Project 62
Old 06-29-2008, 11:00 PM   #13
COMP
city and highway driving 99.9% rest gravel
Old 06-30-2008, 12:51 AM   #14
COBALT
COBALT's Avatar
Rebuilt my entire front-end with Moog parts back in 2002. Rock solid. All you need is a grease gun.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 06-30-2008, 11:13 AM   #15
COMP
got it and its used,,,,,,how many miles you have on the rebuild ?
Old 06-30-2008, 05:17 PM   #16
COMP
found out Napa's low line is off-shore and there Chassie Line is SealedPower
Old 06-30-2008, 09:43 PM   #17
79gmcsierragrande
30-35K??? Seems like you should get more then that out of it. Did you hit something maybe? Like a big pot hole or a curb? Or it could be an underlying problem like bad alignment, oversized tires (too wide especially), aggressive turning, bad gear box, any number of things. With out looking at your truck it’s hard to say. I expect to get at least 100-150K out of my front end job, then again I’m replacing everything:
Rag joint
Gearbox (cardone)
Pitman arm (Moog)
Tie rods (Moog)
Adding a steering dampener (Moog)
Idler arm (Moog)
Keeping spindles and the bar that attaches to the tie rods they’re in good shape
Ball joints upper/lower (Moog)
Control arms (making my own)
Control arm shafts (Moog)
Adding sway bars front and back (Addco)
Control arm bushings (Energy Suspension)
Body mounts (Energy Suspension)
Shocks (Rancho)
Old 06-30-2008, 10:06 PM   #18
COMP
got back from the Zone,,,,,the $8 end was China the $13 was Mex. ,,the side by side was amazing ,,,,the $8 would work for a car,,, but at 4280lbs min.
I wouldn't try it ,,,wish i has Napa closer to see a good one
Oh well tape measure and tools tomorrow
Old 06-30-2008, 11:01 PM   #19
GMBowtie79
GMBowtie79's Avatar
Your going to find that all large companys have parts manufactured in foreign countrys. Labor is cheaper which cuts costs. That dosn't neccesarily make the product poorer in quality. Alot of the GM crate engines are made in Mexico some of the trannys are made there too. Every company does whatever they can to cut costs and increase profit thats just how big buisness works. It's all about the bottom line.
