Old 07-08-2008, 08:43 PM   #1
ton*loc
ton*loc's Avatar
th350 vs. lock out th350
i tried searching but came up just shy of the info i was looking for.
the guy who had my truck before me just had the lockout 350 rebuilt so i dont want to get rid of it if i dont have to. i was just wondering on a stock rebuild how strong are they ? will they hold just as much power as a old school th350 ?
1986 chevy c10 in the "build" process as we speak 358 flat tops, vortec heads, .500 lift cam, NOS power shot plate system, yada yada yada
MMA PIX http://www.clgpix.com/MMA/Fighters/F...C/CoteTony.htm
MMA RECORD 24-5
ton*loc is offline   Reply With Quote
Old 07-09-2008, 06:00 AM   #2
D13
D13's Avatar
Re: th350 vs. lock out th350
The trans guts are the same. The difference is the lock up clutch in the converter and the fluid path for it.
The converter clutch will not withstand heavy abuse, i.e. 400+ hp in 3rd gear with the clutch locked on. It is designed for 5-10% better fuel economy at highway speeds.
there shoul dbe an electrical circuit that shuts off the clutch at high throttle (or low vacuum).
As long as you aren't putting way too much power to it in 3rd gear it should be fine.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 07-09-2008, 07:50 AM   #3
ton*loc
ton*loc's Avatar
well when i got my truck the little four prong plug had been unplugged so the lockout is not even working.
MMA RECORD 24-5
