Old 06-24-2008, 10:28 AM   #1
Hittman
From C/20 to K/20 in 3 months
No the 3 months to do a body swap is not that impressive but considering I have never done it gives me some satisfaction for sure. Just got the exhaust installed last week as the finishing touch to get the beast back on the road. Fortunately everything seems to be in good working order, brakes, steering, tranny...you know, the important stuff. I do have a couple issues of leakage around the input shaft seals on the rear end as well as the front pumpkin. The rear seems to be getting worse the more I drive - it's actually starting to leave puddles. Not sure what it will take to replace but I need to get at it soon. I am posting this in both the 67-72 and 4x4 message boards as I have questions for the 4x4 guys below.
Heres the build progress (short version): I bought the fairly clean bone stock farm truck in Feb. 07 with about 56,000 on the clock and drove it until this past February where the odometer read 58,800. I located a '71 4x4 frame which was already prepped with POR15 and new brakes and bought it for $300. I began tearing the truck down around the first of March and by April had most of the parts scattered all over the place. A neighbor of mine who has a nice '71 K10 was swapping out his small block 400 for a more fuel efficient 350 with fuel injection. He bought the 400 about 10 years earlier with about 30K on it (came out of a '72 Caprice grandma grocery getter) and re-ringed it, replaced the bearings, put a double roller timing chain and a mild cam. He put about 60K on it before he came across this late model small block. I bought the 400 for $300 and sold my original 350 to a friend for $300. Through many delays in timing to get friends and neighbors to help with the body transfer, issues with finding certain parts, and my overall lack of knowledge in any of this I finally got it running and on the road last week. I can't tell you how good it feels to be driving it again....despite the extra dollar per gallon gas went up during that time! That 400 runs real strong though I'm sure those extra 50 cubes will drink a bit more. So yeah I kind of created a mut out of it all however. I call my '69-'72 now. '69 tranny and transfer case, '70 body, '71 chassis, and a '72 small block.
Anyway, thanks to all here who chipped in their help when I got stuck on various issues throughout the build. You all have been a big help in my quest to complete this. I would like to find some better wheels for it sometime - I sold the previous chrome wheels to fund the new exhaust. For now the stockers will have to do. Haven't determined if it looks better with or without the dog dish hub caps - what would you guys suggest for wheels? I'm not a big fan of GM's stock 8-bolts. I understand the 8-bolts from F**d and D##ge may work on these. Otherwise will have to go with aftermarket rims and as you know can get rather expensive. My next push will be to get the body prepped for paint. I think I am on a 2 plus year plan for that however as money as always is tight. I do have a nice rust free and straight box in line right now. Other than rockers the rest of body/cab is in great shape.
Question for you 4x4 guys - I currently have a '69 Rockwell and man is it a whiner. My brother has a '71 NP205 bolted to the back of a TH350 that he is getting rid of.. I am fine with keeping my 4-speed since I really don't want to swap a steering column, pedals, linkage, etc. What does it take to adapt the 205 from an auto to my tranny? I have recently seen a thread on the how to for the swap from the Rockwell to 205 but wasn't sure what else would be necessary for my situation. Would you all recommend I go to the trouble of swapping them or just live with a little extra noise going down the road? No idea on how many miles or abuse are on either transfer case. I know the 205's are much more abundant thus easier/cheaper to rebuild. Not sure I really want to go to the trouble if it's not worth it. What can I look for to determine if either is in need of a rebuild?
Thanks again all for your help!
1970 C20 350 4-Speed no options but only 56K original miles.....Now a K20 mutt with a SB400!
2002 Impala LS (wife's car)
Hittman is offline   Reply With Quote
Old 06-24-2008, 10:56 AM   #2
Yukon Jack
Yukon Jack's Avatar
Re: From C/20 to K/20 in 3 months
First off, I think you have done a wonderful job and 3 months is fast in my book! My projects always take way too long since free time is hard to come by.
In relation to the Rockwell T221, I would recommend that you verify it is full of fluid. Assuming it is, I think you ought to just enjoy driving the truck and worry about replacing it later on. Rockwell's are loud but at least for me, it wasn't an annoyance.
My Rockwell got low on oil a few months ago and took out a set of bearings so I am in the middle of swapping it out for an NP205. My thread on the differences between a Rockwell T221 and the NP205 is proably a page to two down at this point.
I actually like the rims you have on your truck right now. No need for hub caps to me.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 06-24-2008, 07:14 PM   #3
va_tlc
va_tlc's Avatar
i agree 3 months you done a great job!!! and like yukon said enjoy it for awhile b4 ya tear into it agian. i like the white plain wheels also.
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
va_tlc is offline   Reply With Quote
Old 06-25-2008, 05:48 PM   #4
Hittman
Thanks guys for your input. It has been fun and there is definately a sense of accomplishment when you fire it up for the first time and hit the road. It definately turns some heads now and I have gotten a few compliments already. Like you guys say, why fix it if it ain't broke! I have since insulated the floor better filled the holes with some old carpet pad insulation which has made a huge difference. I have yet to get boots for both shafts or carpet which should help a bunch also
I am actually trying to come up with a center console that will work around the sticks giving me a place to insert speakers and a little room for a drink holder...yeah should be interesting if I can accomplish this goal. Actually if there is anyone out there who has done such a feat of engineering please post your pics. I don't want to go to bucket seats just to make room so anything made for the stock bench would be great. There just aren't too many places to insert speakers in these old cabs without cutting into the doors which I don't want to do either.
Thanks again guys.
Old 06-25-2008, 08:19 PM   #5
74 C-30
Dually Pride
74 C-30's Avatar
if you want a spot for a drink holder, is een in yearone and maybe other places too, cup holders that slide into the ash tray socket...kinda neat i think.
...or get one of those belt loop mount cup holders! i saw those up at bike week...theyre pretty funny...
If I have to explain, you wouldn't understand.
'74 Chevy C-30 350/4 speed/dually
'94 Ford Ranger
74 C-30 is offline   Reply With Quote
Old 06-30-2008, 10:44 PM   #6
Joesjunk
Joesjunk's Avatar
Good job, Great looking truck!!!!!
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 07-01-2008, 04:38 PM   #7
milner
milner's Avatar
Wow, truck looks great! Oh and my swap is now on month month 8 and still not done, three months is good.
355,vortec heads, Doug Herbert cam, Performer intake, 750 Holley, Hooker Comps, 2 1/2 duals w/Aero Chambers, 2500 stall and 3.73 posi.
milner is offline   Reply With Quote
