Old 07-02-2008, 03:38 PM   #1
lunaelement
Exclamation Need Help, interchangable parts 1968 C10
I am starting a new build and it happens to be my first truck. I just bought a 1968 C10 long bed and want to know if the rear end, front spindles, from a 1985 Cherolet Van fit my 1968 c10?
lunaelement is offline   Reply With Quote
Old 07-02-2008, 05:40 PM   #2
Gray Ghost
Gray Ghost's Avatar
Re: Need Help, interchangable parts 1968 C10
Welcome to the board....first the rear axle issue. You have a coil spring setup now right? The newer axles were mostly leaf sprung so it's not a direct bolt in. You'll be grinding & welding for sure....we've done this on 2bits truck and it was quite the job.
On the spindles I am not sure, but if they are the same as the 73-87 trucks the whole front end will swap in to take the place of yours.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 07-02-2008, 06:27 PM   #3
Wrenchbender Ret
Measure the width. Usually the van parts are much wider.
Wrenchbender Ret is offline   Reply With Quote
Old 07-03-2008, 04:25 PM   #4
lunaelement
Thanks ..looking forward to being a part of this forum. This is my first truck so I'm sure I will end up having alot of questions. Any information is greatly appreciated.
Thanks again
