Old 07-06-2008, 02:14 AM   #1
1969 k/10
1969 k/10's Avatar
Engine year
Where is the number on the block that will tell me the year of the engine??
Thank you
1969 red k/10 with sb350
4.11 gear ratio, front disk, 3 speed automatic
1969 k/10 is offline   Reply With Quote
Old 07-06-2008, 06:45 AM   #2
caminokid
Chevy nut
caminokid's Avatar
Re: Engine year
You can look up the suffix code on the front of the motor. Right side of the motor under the alternator. There will be a little pad right below the head.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 07-06-2008, 09:33 AM   #3
Shyguy
Junior Member
Shyguy's Avatar
Re: Engine year
If it is a V-8 there is a number on the front of the engine on a flat pad just below the passenger side head.
Then you can go to Mortec or other sites to decode it.
If you can't find a site, just post it here and some one will be happy to decode it for you.
Danny
Shyguy is offline   Reply With Quote
Old 07-06-2008, 06:46 PM   #4
1969 k/10
1969 k/10's Avatar
Re: Engine year
i can see the pad but it is just blank.Could it have been scratched off?
Old 07-06-2008, 06:52 PM   #5
Shyguy
Junior Member
Shyguy's Avatar
Re: Engine year
It sounds to me like someone may have machined it off.
The only other place I know of is there are some numbers back by the distributor that can be used to determine what engine you have.
Danny
Old 07-06-2008, 06:55 PM   #6
1969 k/10
1969 k/10's Avatar
Re: Engine year
Danny
Thers was one by the oil filter too but that 1's not there.
Is it behinde the distributor?
Old 07-06-2008, 08:09 PM   #7
Shyguy
Junior Member
Shyguy's Avatar
Re: Engine year
This is information is listed at "mortec.com". "The block casting number on smallblock and big block Chevy V-8 motors is located on a ledge found at the rear of the block, most often on the driver's side. This ledge is below the deck of the block and the ledge forms the mating surface between the block and the transmission bellhousing."
Hope this helps.
Danny
