Old 07-30-2008, 12:50 AM   #1
Pushrod226
Leaf spring bolts
I plan on removing my rear axle again for a couple hours. While its out I'd like to replace the 1 bolt in each leaf spring pack that holds the pack together and aligns the axle with the springs. What is the size of those bolts?
The last time I seen them they were rusted beyond thinking about trying to remove them so I left em' alone. I figure this will be a good time to mess with them.
BTW 77' chevy shorty 1/2 ton with 6 leafs.
Pushrod226 is offline   Reply With Quote
Old 07-30-2008, 08:26 PM   #2
79gmcsierragrande
Manual Transmission Club
79gmcsierragrande's Avatar
Re: Leaf spring bolts
You’re going to want to replace your shackle bushings while you’re at it. If the bolts are that far gone the bushings will be too. You can go the this site to look for sizing:
http://www.energysuspension.com/pages/c2wd2.html
and I have good dealing s with this site to buy them:
http://www.energysuspensionparts.com...s.asp?cat=2330
79 GMC Sierra Grande, SWB, Heavy Half
If I wanted easy I would just buy a NEW truck!
79gmcsierragrande is offline   Reply With Quote
Old 07-30-2008, 10:45 PM   #3
Pushrod226
I replaced the leaf and shackle bushings, all the bolts(except the 2 that hold the leafs together), the shackles and hangers, U-bolts, and flipped the rear last year.
The only thing I didnt do was replace those bolts that hold the leafs together.
Anyway, I made a mistake up there. I have 5 leafs... Checked it while I was at work today.
Old 07-31-2008, 12:21 AM   #4
joe231
joe231's Avatar
they are special bolts, you should be able to pick them up at a local drive-train shop. i believe they are extra long and you just cut the excess off after they are installed
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 07-31-2008, 01:04 AM   #5
COMP
they are ,,,,remember to clamp before cutting the old one
COMP is offline   Reply With Quote
Old 07-31-2008, 01:58 AM   #6
79gmcsierragrande
Oh I misunderstood, looks like these guys have you covered.
Old 07-31-2008, 02:47 AM   #7
Pushrod226
Cool, Thanks. I'll check out the spring shop on friday.
Old 07-31-2008, 03:00 AM   #8
COMP
and let us know
Old 07-31-2008, 12:28 PM   #9
wedgemon
wedgemon's Avatar
Yep! Replace them. Mine was 35 years old and looked like this...
Bottom 2 springs shifted 2 inches rearward and sheared the rest of the pin/bolt.
Replace the U-Bolts too!! They
stretch and weaken.
- Dave
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
