notch or not
I have a 67 short box with a 4 1/2 / 6 drop, It will be a limited street/Strip truck. I was wondering if it needed a notch,I don't have the BBC or trans installed yet and not sure how much clearance I will have once its in. The drop is with 2 1/2 spindles and 2 inch springs front and 6 inch coils in the rear. I have installed a 15 gal fuel cell and the battery in the rear for weigh transfer,Thanks Brian
Re: notch or not
you should to have the correct suspension travel. even if your using air bags.
Happy to be here
![]() Join Date: Mar 2000
Re: notch or not
If it's under construction, notch it and be done.
Re: notch or not
