Old 08-12-2008, 11:39 PM   #1
brawley
Easy Does It
brawley's Avatar
What electric fans work on these trucks?
I'm looking to put an electric fan on my 63', is there one I might could find at a junkyard from another vehicle that would work? or a nice kit that would mount up with the holes on the sides of the radiator? thanks
brawley is offline   Reply With Quote
Old 08-13-2008, 12:43 AM   #2
leftcoast66
leftcoast66's Avatar
Re: What electric fans work on these trucks?
I used a 16" permacool from summitracing. Was 90 or so and flows 3000cfm. Keeps my c10 nice and cool and uses some fancy zipties to hold it on which go through the radiator
leftcoast66 is offline   Reply With Quote
Old 08-13-2008, 08:36 PM   #3
TR65
TR65's Avatar
Hey Brawley,
I used twin SPAL fans that come mounted and built a frame out of aluminum angle that bolts to the existing shroud holes, no modification to the truck. It works real good. I used the SPAL variable speed fan controller that runs one fan low speed, or one fan high speed, or both fans high speed depending on what is needed to control the temperature. Pretty clean solution.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 08-13-2008, 08:50 PM   #4
joe231
joe231's Avatar
^nice setup!!
very clean
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 08-13-2008, 09:04 PM   #5
coolair
I second the Spal dual fan setup. I used and adjustable engine temp switch and a trinary switch to turn on when needed.
coolair is offline   Reply With Quote
Old 08-13-2008, 09:41 PM   #6
scotts62
One day...
scotts62's Avatar
Wow yea that is a nice setup! looks good!
Scott
93 crew cab build
Project 62
Old 08-13-2008, 10:51 PM   #7
brawley
Easy Does It
brawley's Avatar
Hey thanks for the info.! where did you get the SPAL fans? do you know the model, how much were they? thanks
