Got 20's????
I used the original shims. One of them I had to grind .005 off it on the opposite side of the ring gear. Now when I drive it there is a clicking sound inside the diff. and you can also hear a whine that sounds like a power steering pump. Any ideas. YES there is gear oil in the diff. with Limited slip additive.
------------------ 72 Chevy C/10 87 Chevy Silverado 4X4 www.geocities.com/chevylwb/chevylwb.html Aberdeen South Dakota WANTED: Drop Spindles F/S: rebuilt Turbo 400 & Aluminum wheels w/ tires
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged 02 Sierra Ex-Cab 4wd 2500 HD The 72 went down the road. |
Careful, they attack...
You should have used a new set of shims, the whine is from the gear being out of alignment. The clicking could be from the clutches being worn. I would take it out and use a new set of shims. Just my opinion.
------------------ 69 swb - in the process of being torn down and born again! |
