Old 10-20-2008, 10:36 PM   #1
Ricks1971
Ricks1971's Avatar
stepside fender felt or rubber?
hey guys what is the best product to put between the stepside fenders and box. I have the box apart for paint and need to know what you guys have used and what works best. Thanks Rick
Ricks1971 is offline   Reply With Quote
Old 10-20-2008, 10:58 PM   #2
Mudder
Mudder's Avatar
Re: stepside fender felt or rubber?
I used the vinyl/leather type webbing. Has a small round bead on one edge. You have to notch it to get it to fit properly and position it in place as you tighten the bolts. Not really that noticeable.
Mudder is offline   Reply With Quote
Old 10-21-2008, 01:04 AM   #3
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Your local body shop carries a GM seam sealer material that was used during assembly between the body panels. It is inexpensive and original.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 10-21-2008, 07:56 AM   #4
JimKshortstep4x4
I used the welting like Mudder used and also used a ureathane sealant for a leak proof joint.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 10-21-2008, 08:25 AM   #5
67ChevyRedneck
67ChevyRedneck's Avatar
I glued mine in place first.
Then bolted it to the truck.
I installed it to keep the paint from rubbing more than anything. I'm not to concerned with rust. I keep the truck clean and I coated the crap out of everything with eastwoods rust encapsulator. So far so good?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-21-2008, 09:25 AM   #6
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
I like the idea of gluing the welting in place first, what kinda glue did you use ???
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 10-21-2008, 09:44 AM   #7
67ChevyRedneck
Ready to laugh?
It was a can of "elmers" all purpose glue. It comes in a spray can and it said it was good for wood, metal, plastic, etc... I taped off the fender sprayed it on (you can see the spray can in the pic). Sprayed it on the back side of the felt, let it get tacky, then stuck it on. I did about 1' sections at a time. To get a good fit, I also cut triangle sections out of the welting to go around the curves better.
Jesse James
Project "On a Dime"
Old 10-21-2008, 04:39 PM   #8
Brock
upgrading to an older model
Brock's Avatar
i don't mean to jack but...what if you don't use the felt/welting? I put mine on what was supposed to be temporarily without the felt/welt but half way through I found it such a pain in the hinney that I went ahead and tightened everything down. whats gonna happen?
68 stepside, short-box, multi-colored (for now)
Brock is offline   Reply With Quote
