Old 10-07-2008, 08:16 PM   #1
drivethechevy
drivethechevy's Avatar
help
im new to engines, and i am trying to replace the original timing gears on my 74 350, i pulled the gear attatched to the cam and the chain no problem, but i cant get the crank gear off, i tried the only pronged puller i have to pull the old gear off the crank and it moved a little then my puller busted,
there has to be a better way to pul this gear off
thanks
nate
Trial and Error, its expensive but its a mistake i most likely wont make again
1971 chevy k10 custom deluxe
http://67-72chevytrucks.com/vboard/s...d.php?t=341257
1968 chevy k/10 fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=334731
1948 desoto custom coupe fluid drive(family heirloom)
drivethechevy is offline   Reply With Quote
Old 10-07-2008, 08:43 PM   #2
wyatt earp
Re: help
i've had luck taking a rubber headed striking mallet and tapping it back towards the motor then see if the key way will come out. if not then find a bigger gear puller.
wyatt earp is offline   Reply With Quote
Old 10-07-2008, 09:27 PM   #3
drivethechevy
Re: help
the keyways i have seen before have been one peice, the keys on my crank are seperate and when i removed the harmonic balancer the first key did not fall off, is that normal?
thanks
nate
Old 10-07-2008, 09:56 PM   #4
harshard
Re: help
thats normal but you will probably want to remove the harmonic ballancer key before removing the gear , to be on the safe side.
harshard is offline   Reply With Quote
Old 10-07-2008, 11:04 PM   #5
drivethechevy
Re: help
whats the best way to go about removing the keys?
thanks
nate
Old 10-07-2008, 11:35 PM   #6
jsbgump
Gone Fishing
jsbgump's Avatar
Re: help
I have used a 3 jaw puller to remove the crank gear before
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 10-08-2008, 07:24 AM   #7
70GMCer
70GMCer's Avatar
Re: help
Some will not agree with this, but since you are not going to use that crank gear anyone, take a steel chisel, and hit between the teeth of that gear a couple times. That cast gear will break right off. Just make sure to put a rag behind that gear to prevent anything from going into the pan. I've been doing it that way for years.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 10-08-2008, 07:36 AM   #8
truckdude239
truckdude239's Avatar
Re: help
if its not woren real bad i just leave it i've never had any problems
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
