10-13-2008, 08:12 PM | #1 |
.....I am working on it.....
Dana 44 knuckle question
I am looking for replacement knuckles for my '72 Blazer. The knuckles I sold have the numbers 35686 and 35687. What do these numbers represent? I need new knuckles, but the ones I am looking at have a different number number at 35663 and 35664, but look the same. Are they still the same? Thanks.
10-13-2008, 08:30 PM | #2 |
Re: Dana 44 knuckle question
Check the taper where the tie rod goes into the knuckle. Does it taper from the top or bottom? 1972 should be from the top
10-13-2008, 09:09 PM | #3 |
Yeah, its tappered from the top. Larger hole on the top side. I just want to make sure the difference in the casting numbers are still the same knuckle. I will be drilling the holes for a 3/4 bolt/heim anyway. Thanks.
10-14-2008, 10:38 AM | #5 |
No difference that I can think of, unless the replacement is not of a flat top casting. Either way it should work just fine
