Old 10-13-2008, 12:35 PM   #1
gintaras
OEM paint method? How to tell if it is factory paint.
I was told that my truck was a "survivor", original paint, etc...
But upon further inspection, i am not quite so sure about this, but the more I look, I question it.
Color is Dk Olive/White 2-tone. The truck only has 68k miles and was always stored indoors, no perforation rust, just one small area of surface rust on the passenger rocker.
The lines between the white and green, they are OK, but there is some bleeding in spots, is this what a factory job looks like?
even after thinking it couldnt be factory, I look closely for some transition lines near the rockers, under the hood, etc, and I can't find any, so now I am second guessing, maybe it is factory paint...
any tell-tale signs? the paint is not faded because it was wet-sanded and buffed before I bought it. Are the lines always smooth with no ridge? or is there a bit of a small ridge between the white and the color? Did they use tape at the factory for the 2-tone? what does the tape line look like at the wheel well? is it horizontal? or does it kind of go up at an angle as it (the tape) wraps around the corner?
2004 VW R32 450 HP money pit (faster than a Viper in the 1320 )
2001.5 VW Passat beater
1972 Custom Deluxe Highlander 69k miles and counting, all original, even the paint
gintaras is offline   Reply With Quote
Old 10-13-2008, 01:00 PM   #2
FIVE 0
Re: OEM paint method? How to tell if it is factory paint.
A trained eye can see the very small details that may have been missed on even the best repaints. If the truck has original paint it will have a ridge between the colors, this is because its single stage and not cleared. That in itself does not make it original. Pics of some of the things your talking about may help. The easiest way you could be sure is to go to a reputable paint shop, thats not talking you into a repaint, and get the painters opinion. Overspray in doorjambs, rubber, wheel wells, frame, etc. Again "if" it was repainted, the better the job, the harder it will be to detect. The one thing that is hardly ever removed is the vin plate on the in the door jamb on the drivers side. Look very close at it and it may tell you.
FIVE 0 is offline   Reply With Quote
Old 10-13-2008, 01:07 PM   #3
70cst
70cst's Avatar
Another way is to look under the rubber seals. Sometimes these are just masked when painted so one might see the original paint under the rubber seals. Just an idea.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 10-13-2008, 01:13 PM   #4
gintaras
did they use 2-sided tape on the trim back then? or was it strictly clips? I found that at least on the passenger side, there is 2-sided tape to suplement the clips. But even so, that doesn't necessarily mean it was painted.
aAnd speaking of the seals.. I looked, and looked, no overspray, I even pulled up on the seals and looked underneath and there are no lines.. I pushed up the rear window seal, still, no paint lines, only yellowed paint. As it stands, the white is bright, but I think that was brought out with the buff.
Old 10-13-2008, 01:29 PM   #5
MrGoodpliers
MrGoodpliers's Avatar
Clips all they way through '70. '71-'72 use double sided tape type in the middle and bolt-on (usually) or push-in on the ends.
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC...
MrGoodpliers is offline   Reply With Quote
Old 10-13-2008, 01:30 PM   #6
WIDESIDE72
WIDESIDE72's Avatar
Sounds original to me. If it looks good,personally I would not worry about original vs repaint, unless the seller is asking an exorbitant amount for it because it supposedly has original paint.
WIDESIDE72 is offline   Reply With Quote
Old 10-13-2008, 05:31 PM   #7
primered_junk
ASE master tech/machinist
primered_junk's Avatar
Another way to tell is the paint lines under the trim will not be straight. The doors will have a slight rise in the paint on the bottom color. Dont know why but most did. My 72 is a true one owner survivor, I purchased it from the original owner, who happened to own the dealership that sold the truck.
"I sit here and I pray in my broken down Chevrolet....."
primered_junk is offline   Reply With Quote
Old 10-13-2008, 07:47 PM   #8
gintaras
Thanks! Well that sums it up then.. the ironic thing is that because of these factory flaws, that is what led me to suspect the sellers claims..
Now, if you tell me that inside the doors, the 2 colors are not straight, then then my question has been answered, thanks again!
Old 10-13-2008, 08:25 PM   #9
Joesjunk
Joesjunk's Avatar
Sounds like a great truck!! Lets see some pics!!! I love original paint!!!
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 10-13-2008, 09:00 PM   #10
gintaras
Here ya go, i will get some paint pics this weekend
(notice the previously mentioned "upward slanted tape line" in the wheel well.
Old 10-13-2008, 09:31 PM   #11
Joesjunk
Joesjunk's Avatar
WOW, Nice suvivor!!!
Old 10-14-2008, 07:40 AM   #12
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Also, check if there is a grease pen writing on the top of the firewall, if not, it was either wiped off or painted over.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 10-14-2008, 09:32 AM   #13
It sure is a nice Highlander.I see the lower trim on the fender front is riveted.
Old 10-14-2008, 09:49 AM   #14
gintaras
yeah, there is a small scrape there and the PO used screws to hold the trim down.
Old 10-14-2008, 11:30 AM   #15
Oh,ok.
Shouldn`t the paint on the upper door be white on the inside?
Old 10-14-2008, 11:35 AM   #16
72highlander
Sophomore Member
72highlander's Avatar
Oh,ok.
no, just the lip of the door skin itself should be white, just got through painting one for a guy and looked at a lot of trucks to make sure.
1972 Chevrolet Highlander SWB
1972 Custom Deluxe 3/4 2WD 60k miles
these trucks don't need vacuum gauges cause they don't suck!
two wrongs don't make a right, but three rights do make a left
all i want is a little more than i'll ever get
it's better to be judged by 12 than to be carried by 6
72highlander is offline   Reply With Quote
Old 10-14-2008, 09:20 PM   #17
va_tlc
va_tlc's Avatar
wow, regardless of a re-paint or not, thats 1 fine looking truck.and if it has been and your still looking to find the signs, he was one heck of a painter
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
va_tlc is offline   Reply With Quote
Old 10-14-2008, 09:45 PM   #18
67CHIP72
STOLEN
67CHIP72's Avatar
Agreed, fine looking truck in unbelievable condition! Where did you find it and when?
In Search Of
67CHIP72 is offline   Reply With Quote
Old 10-14-2008, 10:24 PM   #19
OARNGESI
OARNGESI's Avatar
Rteally nice truck i like the seat
OARNGESI is offline   Reply With Quote
Old 10-14-2008, 10:29 PM   #20
gintaras
Found it in Cleveland TX, courtesy of ebay, about a month ago
I like it too, but needs new foam, the drivers side is pretty well broken in.
Old 10-14-2008, 10:48 PM   #21
67CHIP72
STOLEN
67CHIP72's Avatar
"I like it too, but needs new foam, the drivers side is pretty well broken in."
You might get by with an additional coil spring along the outside or some spring repair. I would take it to a good interior shop for suggestions and make sure nothing is broken first.
P.S. Have you checked behind the seat for the build sheet? If it is there, make sure they don't pitch it if you get the foam replaced(assuming you are not doing it yourself).
In Search Of
Old 10-15-2008, 07:04 AM   #22
I stand corrected on the door paint.You have me looking hard.I saw somepictures painted white inside and can`t recall the ones I`ve had.No 2-tones at the moment.
My upholstery guy says when he does my seat like that he will add hardboard under the foam to stiffen the worn springs.He says you can`t flip them.I`m going to try that until I get it covered.I can`t stand sinking down in the seat.
Old 10-15-2008, 09:22 AM   #23
va_tlc
va_tlc's Avatar
wonder why the seat would be sagging so bad with the truck only having 68,000?that seems kinda strange, but im sure the weight of the driver plays into this,
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
Old 10-15-2008, 09:54 AM   #24
That`s what I figure mine was,a big boy owned it.
Old 10-15-2008, 09:58 AM   #25
gintaras
It's not that bad, it just the corner has not much support, so when I drive it, I scoot towards the middle a little.. years or sliding in and out and putting pressure on the corner of the seat surely wore it a bit. It's not that bad really, just a little low on the far left side.
