Old 10-09-2008, 12:37 AM   #1
79gmcsierragrande
Manual Transmission Club
79gmcsierragrande's Avatar
Steering done... Finally!!!
Well I finally got the truck put back together. It’s been on jack stands for almost 5 months now, I’ve been busy. It started because of a drifting problem but I wanted to replace everything anyways. I’m not done with everything yet but I’ve got it to where I can take it to get it aligned. I’ve spent $2144 just on the steering and suspension. Oh and I also put new tires and rims for about $815.
Water Pump
Radiator and heater hoses
Belts
Front bearings
Wheel studs all around
Lug nuts all around
Battery
PS pump
Steering Damper
Tie rod sleeve
Tie rod ends
Idler Arm
Ball Joints
Pitman arm
Control Arms
Control Arm bushings
Control arm shafts
Control arm U bolts
Bumpstops
Front & rear sway bays
Shocks
Leaf spring bushings
I still need to install the sway bars and leaf spring bushings.
I already had a couple of threads started on this with pictures and what not.
http://67-72chevytrucks.com/vboard/s...d.php?t=309218
http://67-72chevytrucks.com/vboard/s...d.php?t=308744
79 GMC Sierra Grande, SWB, Heavy Half
If I wanted easy I would just buy a NEW truck!
79gmcsierragrande is offline   Reply With Quote
