Old 08-13-2008, 09:27 PM   #1
ofnaman
ofnaman's Avatar
in line 6 Question
Anyone know if a 250, or 292 head will fit on a 235? I've heard they will, but I want to be sure. Thanks
A sweet 2000 Deville.....
ofnaman is offline   Reply With Quote
Old 08-13-2008, 10:53 PM   #2
pugs
pugs's Avatar
Re: in line 6 Question
i really dont think they will interchange
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done...
pugs is offline   Reply With Quote
Old 08-13-2008, 11:08 PM   #3
cajundragger
I know a 292 will not work. A 292 is huge.
cajundragger is offline   Reply With Quote
Old 08-14-2008, 05:08 PM   #4
rstrick
"Anyone know if a 250, or 292 head will fit on a 235? "
Don't think so. Completely different designs.
rstrick is offline   Reply With Quote
Old 08-14-2008, 06:20 PM   #5
mbgmike
no
mbgmike is offline   Reply With Quote
Old 08-15-2008, 12:30 AM   #6
murdoc
murdoc's Avatar
absolutely not!!!!! no way. although the 292 and the 250/230 all share the same head
murdoc is offline   Reply With Quote
Old 08-16-2008, 12:37 AM   #7
ofnaman
ofnaman's Avatar
Don't know if this has been posted before, but I found a neat site for inline engine's. Unfortunately, the site does not have a lot of specifics, but it is pretty neat to see some heavily modified inlines. The site is http://www.inliners.org/. Check it out.
Old 08-16-2008, 09:06 AM   #8
Gene Sharp
but some of the 261 inline sixes I believe do share some parts
Gene Sharp
Gene Sharp is offline   Reply With Quote
Old 08-16-2008, 02:16 PM   #9
BigBlocksRule
Will a 230/250/292 fit in my '55 2nd without a lot of mods? It started out with an inline 6 but it's long gone. I'm considering safety upgrades (power steering, power disc brakes) but want to keep the straight axle and would really like to have a straight 6, even if it's not the right vintage.
BigBlocksRule is offline   Reply With Quote
Old 08-16-2008, 03:42 PM   #10
Fred T
Cantankerous Geezer
Fred T's Avatar
Nothing interchanges between the 235 and the 250. The 194/230/250/292 series was a totally new design using standards from the small block V8. You can take two V8 heads, cut them and weld them together to make a cross-flow head for the newer six, but you also have to drill new head bolt holes. The valve-train is from the big block.
As for dropping a 250 in an older truck, it is relatively easy. The block is narrower, so different mounts and perches are need. For those contact Tom Langdon at www.stoveboltengineco.com
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 08-16-2008, 03:48 PM   #11
BigBlocksRule
Thanks, Fred, I appreciate the info. I've ordered the inline 6 performance book and have a few engines to choose from since most folks have discarded 'em in favor of V-8's. I have access to 700R4 and 2004R trannies, just need to pick one.
Old 08-16-2008, 07:40 PM   #12
cajundragger
I was so close to doing a turbo'd and injected 292 with a muncie 4 speed in my truck. went a different direction though.
putting a 4.2L trailblazer 6 in my Dads 56 though.
Old 08-16-2008, 08:18 PM   #13
Fred T
Cantankerous Geezer
Fred T's Avatar
That would be one wicked (and expensive) powerplant. I doubt if the muncie would last very long, even the M22 is way over-rated. One of the newer 5 speeds would be nice. But it's only money.
Fred
Old 10-15-2008, 07:40 AM   #14
OhNoJoe
OhNoJoe's Avatar
good luck on trying to find any info a 4.2 swap. I would be very interested in how the 4,2 swap works. I couldn't find any info at all, Ended up selling my 4.2 for $350
OhNoJoe is offline   Reply With Quote
