Old 11-22-2002, 04:52 PM   #1
86-C10-V6
Shadetree Mechanic
86-C10-V6's Avatar
Harmonic balancer size on 4.3L carb engine
I am planing to do some work on my distributor, new weights and springs and the crane adjustible vacuum advance.
I would like to add a timing tape to my harmonic balancer to allow me to setup the timing but I can't find out what the diameter is on the harmonic balancer.
I have not tried to measure it yet, but I have found a reference on the internet(parts search) that suggest that it is 6 and 1/8 inches.
I can not find a timing tape that is designed for this size harmonic balancer.
This is somewhat complicated by the fact that my engine was replaced in 92 with a GM long block and I remember the mechanic that did the install said the engine had been upgraded to roller cam. I am not sure if the harmonic balancer is the same as the original engine.
Anyone have experience with this engine that can make some suggestions?
Thanks in advance.
Dave M. (Hacksaw)
86 C10 Scottsdale LWB, 4.3L, Edelbrock 1904, K&N, 700R4, 3.08 Auburn Performance
89 GMC S-15 Extended Cab 4x4, 4.3L, FI
98 K1500 Xcab, 5.7L, 3.43 Gov-Lok
86-C10-V6 is offline   Reply With Quote
Old 11-22-2002, 07:28 PM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
I believe it's the same as the 6.75" damper found on SB V8's.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
