47-53 cab to bed distance?
How big of a gap is there from the cab to the box on an AD truck? Can someone with an assembled truck let me know? I'd probably need the measurement in the center of the truck, as the cab is somewhat rounded. Thanks!
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
![]() Join Date: Jul 2007
Re: 47-53 cab to bed distance?
I'm too far from my copy of the assembly book to be able to find out but I'd say that if you have it even up and down and the back of the cab and the front of the bed are square to each other and around 3/4 inch apart you should be pretty close.
the splash guards between the running boards and the bed could be used to get u close
#4 | |
Mr48chev, in your assembly book did they mention factory tolerances for things like diamond measurements for spring perches and body mounts? My truck is in really pretty good shape and hasn't been wrecked, and it appears that the tolerances weren't very tight (as it was built as a truck), just wanted to know what "acceptable" was back then. Thanks!
BlueJeep, the shop manual has a multitude of dimensions listed for the chassis to check (no tolerances I can see). Is this what you're looking for? If so let me know and I'll get you an enlarged readable copy.
Close... in the manual for my Willys I have a page like that and then the one before or after gives tolerances for when you're performing the measurements.
