Old 11-05-2008, 03:25 PM   #1
mateo1279
mateo1279's Avatar
A hair-brained idea?
So, this may sound idiotic to some but.....
I was wondering if one could remove the torsion bars and just stuff some springs between the control arms (or something).
I ask because I have seen people post regarding airbag suspension swaps using this location for the bags, I was wondering if I could do the same thing and just use coil springs?
Trying to weigh out all my options... I don't have the $$$ to do a full front end swap from a later model (actual front end, rebuild, master/booster for disks= big $$)
Matt
1962 Chevy Fleetside
283/TH350
mateo1279 is offline   Reply With Quote
Old 11-06-2008, 10:04 PM   #2
tonythezeek
tonythezeek's Avatar
Re: A hair-brained idea?
when i was pulling my torsion bars off last week I asked myself that same question. unfortunately, i don't know the answer but it looks like it could be done. I guess anything is possible with a blowtorch and a bit of creativity.
tonythezeek is offline   Reply With Quote
Old 11-06-2008, 10:47 PM   #3
slepysal
slepysal's Avatar
you would need diffrent a arms.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 11-06-2008, 11:21 PM   #4
protrash64
Resistance is Futile
protrash64's Avatar
What about adding some coil-overs? Fab up some mounts and you cuold have a nice streetrod front suspension. I dont know about low-buck however. I see coil-overs on the Phx area Craigslist occasionly.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 11-06-2008, 11:46 PM   #5
scotts62
One day...
scotts62's Avatar
Do they even have the pocket under the crossmember for a spring? I dont remember on mine its been a few years.. i got a whole crossmember for $125 wheel to wheel
Scott
93 crew cab build
Project 62
Old 11-06-2008, 11:52 PM   #6
guzzidude
guzzidude's Avatar
My Frankenstein has leaf springs... So I can't make a good comment. I think my frame is an early 60's GMC something...
guzzidude is offline   Reply With Quote
Old 11-06-2008, 11:54 PM   #7
protrash64
protrash64's Avatar
Scotts62: I think it would work, you can bag 'em so there is something to push against. I just dont own one so Im not familiar.
Old 11-07-2008, 12:00 AM   #8
scotts62
One day...
scotts62's Avatar
Ya its been 4-5 years since i did mine and wasnt sure if the ones with tortion bars had a spot for spring to sit, im thinkin no thats why i changed my whole X member on mine... but who knows i could be wrong id have to see one to remember
Scott
93 crew cab build
Project 62
Old 11-07-2008, 12:47 AM   #9
502tripower
502tripower's Avatar
You can find the 73'-87' style trucks for next to nothing or even free. I know I have hauled several home for free. This would be a much better solution.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 11-07-2008, 08:00 AM   #10
born loser
I have seen other makes of trucks with torsion bars that are converted to coilovers. Seemed to work quite well. Depends on your fab. skills, but anything is possible. I will search for the pics so you can see how they were crammed in there.
born loser is offline   Reply With Quote
Old 11-10-2008, 10:09 PM   #11
mateo1279
mateo1279's Avatar
Thanks for the ideas.... a few thoughts:
It sounds like the complete front end swap could be relatively cheap then, huh? I was thinking I would need to dive deep into the wallet to get all the stuff for converting to disk breaks and make all the steering line up..... or is it really just as easy as unbolting the old front, bolt up the new one, hook up the old lines and drive?
I tend to over think things, which is why I was originally exploring this idea in the first place....
-Matt
283/TH350
Old 11-10-2008, 10:30 PM   #12
joe231
joe231's Avatar
just look up
or here LINKY
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 11-10-2008, 10:47 PM   #13
mateo1279
mateo1279's Avatar
Sorry guys, maybe I wasn't clear. Here is my goal:
Get rid of the Torsion bar front end the cheapest way possible.
The idea I started off this post with (cram coil springs between the a-arms)may not work due to the geometry of the vehicle (the a arm issue mentioned above)...though so serious fab work might make it happen, probably not worth the time (plus I am so-so on the true custom fab work)
That being the case I will start doing homework on the 77-89 (dont remeber the correct years off hand) front crossmember swap and see how we're looking. If anyone has some words of wisdom feel free to send em my way (PM or add on here)
Thanks as always!
-Matt
283/TH350
Old 11-10-2008, 11:07 PM   #14
mnky30
mnky30's Avatar
i have a 60 frame and did the cross from tortion bar front end to a 80 3/4 ton front end and it is as easy as taking old bolts out and redrilling some new holes and installing the hole front x member.
vinnie
1960 chevy c10 frame with a 1966 cab
2002 dodge intrepid r/t
2004 chevy 2500 4 door short bed
mnky30 is offline   Reply With Quote
Old 11-10-2008, 11:07 PM   #15
mnky30
mnky30's Avatar
and one more i aslo used the motor mounts from the 80 doner truck and cut 1 coil out of front springs and used the front sway bar front the 80
vinnie
Old 11-10-2008, 11:15 PM   #16
71Farmtruck
Junk Junkie
71Farmtruck's Avatar
That's bad ass, that's the way to do it.
Mike
71 Chevrolet C-10 Short Bed Stepside
81 GMC 1500 Sierra Classic Long Bed
71Farmtruck is offline   Reply With Quote
Old 11-11-2008, 04:14 AM   #17
mateo1279
mateo1279's Avatar
Well shoot.... those pics speak for themselves! That looks pretty simple. One question: This could be done with the engine in and the body on, right? That 1st pic I shows the bolt locations... I think I could get to them on the frame from the engine bay (unless I am missing something), but it looks like the engine rests on the cross memeber. I need to go get uner the truck tomorow and investigate!
How did all the accesories hook back in, easily? I have PS and drum breaks (single master), what did you start with?
Thanks for those pics!
Matt
283/TH350
Old 11-11-2008, 09:48 AM   #18
joe231
joe231's Avatar
the engine sits on the cross member, plus it is easier to get to everything with the engine out.
you could probably raise the engine with a hoist and get it done also, if you don't want to pull it all thee way out
do you currently have power brakes?
you have converted power steering? or original power assist?
CHEVY ONLY
Old 11-11-2008, 12:38 PM   #19
mateo1279
mateo1279's Avatar
I don't have power breaks, I have drums (which are practically flinstones breaks)
I think I have original power assist. I have a resivour/pulley connceted to the engine, with hoses that run to the box
283/TH350
Old 11-11-2008, 12:39 PM   #20
mateo1279
mateo1279's Avatar
oh, and my master (no booster) looks like a matchbox
283/TH350
Old 11-11-2008, 01:20 PM   #21
mnky30
mnky30's Avatar
i think you could do it with the cab on no problem but the engine would have to be lifted or removed and all the accessories brake lines i welded a tab on the frame to mount them and then just got some new brake line and rerouted it to a porportion valve on the frame. the steering i used the original idler arm from the 60 and the rest hooked up to my power steering box i mounted from the 80 frame.
vinnie
Old 11-11-2008, 10:30 PM   #22
tonythezeek
Lifting the engine up will work but I'm finding that it gets in the way sometimes. At one point, I had a ratchet look more like a snake than a tool
Old 11-12-2008, 01:44 AM   #23
mateo1279
mateo1279's Avatar
Ok... so if I am doing my math right....
pulling engine + pulling front crossmember = less overall work and aggrivation then slightly lifting the engine and trying to work around it.
283/TH350
Old 11-12-2008, 01:57 AM   #24
joe231
joe231's Avatar
yep
CHEVY ONLY
Old 11-12-2008, 02:04 PM   #25
502tripower
If you are to the point of lifting the engine you are 95% to having it out. It just makes seance to remove the engine to perform the work. Also this gives you the opportunity to detail you engine or address any other issues. Your best bet it to locate a donor truck 73'-87 1/2 ton or up to 91' 3/4. They all used the same X member but the 3/4 used the big spindle and brakes. You can use everything off of the donor including the master cylinder whether it be power or manual. These trucks are fairly easy to come up with for little or nothing.
98' FXD
2002 2500HD
