accepting donations
Driving on front brakes only
So I did the first real inspection on my new truck this morning and this is what I found.
Left rear pads are gone, just bare metal. Right rear fell apart when I pulled the drum off. All the metal brackets on the right side are chewed up and cannot be reused. I've never driven a vehicle with manual brakes so I thought having to press real hard on the pedal was normal. Also a couple other pictures. Noticed, the tranns lines are leaking at thr radiator. I did wire up the wiper motor so know I can see when it rains. ![]() ![]() ![]() ![]()
1999 Yamaha roadstar 1600 chop. (in progress.) See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/ "Ya'll can go to hell, I'm going to Texas." David Crockett Last edited by theyammieguy; 11-28-2008 at 10:16 PM. |
Dave's not here, man
Re: Driving on front brakes only
That sucks, but at least you discovered it before something catastrophic happened. My trans. lines leaked from that same spot, but I couldn't afford new ones. Instead, I found a piece of flared tubing that the correct size threaded nuts on it (I think it was brake line), cut it in half and threaded either end into the radiator. Then I just used rubber hose to attach the new line to the old line and no more leaks. You probably already knew about this, but I figured I would tell you anyway. Good luck on your brake job...at least the parts aren't crazy expensive.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
#3 | |
accepting donations
I spent all my cash on christmas presents today and only had $40 left so I was able to get the shoes and spring kit. next Friday I will get the drums and all the brackets. Yes, I was one of the nuts at Walmart at 5am. Lol I'll buy some tubing and make my own if a little teflon tape does'nt fix it. Need to go to work and use the torch so I can heat up the u-bolt nuts on the torsion bars and tighten them up. need new bushings just about everywhere. Can't complain though, I knew what I was getting into when I bought it. Just wish there wasnt this much rust. I dont have the tools to repair it nor the money to have someone do it for me.
1999 Yamaha roadstar 1600 chop. (in progress.) See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/ "Ya'll can go to hell, I'm going to Texas." David Crockett Last edited by theyammieguy; 11-28-2008 at 10:03 PM. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
No teflon tape on the cooler lines !
That's a flared fitting. Teflon tape is for pipe threads only. The flared fitting is what seals, not the nut around the flare. Fix the problem right. Either tighten it up or repair the flare with a flaring tool.
accepting donations
I meant where the brass fitting goes into the radiator
1999 Yamaha roadstar 1600 chop. (in progress.) See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/ "Ya'll can go to hell, I'm going to Texas." David Crockett |
dont know what ubolts you plan on tightening //but i do know theres no torsion bars in the truck
accepting donations
Sorry, I don't know the proper terminology. The bars that run from the axle to the frame.
Happy to be here
![]() Join Date: Mar 2000
Those are called trailing arms. Just so you know torsion bars are found in front suspensions.
Sisyphus was my mentor!
![]() Join Date: Sep 2002
I knew a guy who had a 68 Satellite & 3 of the 4 brakes were seized. The only one that worked was drivers-side front & it was either locked or not grabbing at all - no in between!
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
#10 | |
Sierra Grande Club
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
Teflon tape is NOT designed as a sealant either. It's proper use is as a lubricant in order to achieve the proper torque readings.
![]() Join Date: Jul 2007
Unscrew the cooler line fittings from the radiator and take a close look at them to make sure that the flairs are in good shape and true and not cracked. Sometimes if the line is allowed to vibrate it will crack right at the base of the flair.
Also take a look at the fitting in the radiator to make sure that it is in good shape. |
Shane
Teflon tape IS A SEALER. I don't know where you are getting your information,but you are incorrect,it is a sealer. I guess I don't know what I am talking about but I think that being in the plumbing supply business for 32 years ,might give me some credibility. The quickest way to snap off a threaded part is to torque it after the use of teflon. You have to decrease your torque settings if you are using teflon.-KB |
accepting donations
AHH, thanks.
#15 | |
accepting donations
Yeah, Im a tractor/trailer mechanic and teflon tape is an everyday thing in my shop.
#16 | ||
Not to start a pissing match with you but I worked for Parker Hannifin for 12 years as a manufacturing engineer. They are only the largest manufacturer of pneumatic, hydraulic and pipe fittings on the planet. I too know a little about the sealing actions of metal to metal fittings. Quote:
#17 |
Then maybe you can explain to me why you can cross cut a grove(with a file)on a pipe thread and then use a cap,and the caped pipe will hold 200 lbs of air pressure.It has to be sealing,not lubricating,to do that.If you recall,when teflon first came out,that was one of the tests that they performed to sell the buyers on teflon.
If all you had to do is lubricate pipe to make it seal,then why don't pipe-fitters use synthetic oil on threads. If you worked for parker han. you know that pipe threads ,when looked at under magnification ,have a lot of groves and lines where the dies stop.Teflon reduces friction.You want MORE friction if you want the threads to work against each other to reduce flaws in the joining surfaces.Lubrication may be ONE of the characteristics of teflon,but it sure isn't the Only thing that makes it seal.Furthermore,teflon wouldn't pass code if it didn't have sealing properties. Sorry to hyjack the original purpose of this discussion-KB PS,,Last time I checked,,Parker was not even close to being the largest manufacturer of pipe fittings on the planet . Not a pissin contest-as you call it. I just didn't agree with what you had to say,,,STILL DON'T. Your quote says it all; ONE OF THE CHARACTERISTICS of ...... Last edited by 50MOTORHEAD; 11-29-2008 at 03:47 PM. Reason: addition |
#18 |
PM sent.
#19 |
![]() Join Date: Aug 2008
rowr!!! cat fight!!!
#20 |
Sierra Grande Club
I found this on wikipedia
Looks like Shane wins..... s/t "One of the defining characteristics of PTFE is how good it is at defeating friction. The use of PTFE tape in tapered pipe threads performs a lubricating function, which more easily allows the threads to be screwed together, to the point of deformation, which is what creates the majority, if not all, of the seal."
#21 | |
Middle-aged Curmudgeon
![]() Kinda interested to see how this turns out. I'm with Shane-- always understood tape to be a lubricant. A pipe thread by design is a self-sealing thread. The tape makes it easier to screw it together. And Tx Firefighter is right. Take a look at the flare to see where it's leaking. All the threaded nut is doing is holding the flares together. |
#22 |
accepting donations
All I know, is if I did'nt use teflon tape, I would have tractors that would'nt build up air pressure and trailers that leaked product.
#23 |
![]() Join Date: Apr 2004
ftw
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
