Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 12-01-2002, 10:19 PM   #1
wlee
Just an Old Mr Goodwrench
Remanufactured 350 High Performance Engine
I'm getting ready to put this on Ebay, but thought I'd give the board members first shot. I'm starting the Ebay auction at $1500 with a "buy it now" price of $2500 - board members can email offers to wlee@socket.net
Here's the specs:
High Performance 350 Chevrolet Complete engine
Here’s your dream engine, ready to drop in & go!
This is a 1974 Small Block Chevrolet 350 C.I.D., 4 bolt main, cast #3970010, stamp #VO415TJB that’s been professionally re-manufactured.
Cylinders bored .020
Clevite .010 main bearings and .020 rod bearings.
New flat top .020 pistons, original rods tested & reused.
64cc double hump 327 Feulie heads, cast #3917291, 1.94 intakes and 1.5 exhaust valves
Triple ground with new brass guides, Z-28 springs and new valves magnafluxed & milled giving a 10.3 compression ratio.
Fel-Pro 1003 Blue high performance head gaskets
Clevite 229-1713 Hydraulic lash performance camshaft with an advertised duration of 306 intake and exhaust, duration at .050, lift is 222, Valve lift is .447, cam lift is .298, lobe spread is 114
New Johnson HT 817R lifters
Black Moly Push Rods
Black Moly roller rockers 1.5 intake / 1.6 exhaust
Black moly push rod guide plates.
Melling M-55A high velocity Z-28 Oil pump
Melling Distributor drive shaft.
Cloyes double roller timing chain and gears
New Holley 650 CFM electric choke Quadrajet
GM Polished aluminum manifold, GM ID#458520.
New HEI ignition custom tailored for maximum performance.
GM performance polished aluminum valve covers, GM part #141-108 with the Chevrolet logo stamped in red on top.
AC Delco stainless steel bolts
MotorChrome 350 High Performance air cleaner with blue flags
Chrome timing cover
Cal Auto Transpeed Chrome harmonic balancer
Chrome triple pulley
Chrome oil pan and dip stick.
Engine is painted with High-temp ceramic cast coat iron, which compliments the chrome parts nicely.
Fuel pump and water pump are NOT included.
This is a professionally built engine and carries a 12 month limited parts only warranty. Parts are warranted against defects in materials and workmanship. This warranty specifically excludes racing use, any competition, or marine use, and parts that fail as a result of alteration. Should any part prove to be defective, that part, and only that part may be warranted at my discretion. The buyer assumes full responsibility for the full cost of the repair, service, damage and/or loss to property. It is the buyer’s responsibility to check for any state and Federal laws concerning engine replacement, modification, and emissions regulations.
1969 CST 20 Longhorn
1970 CST 20 Fleetside
1991 Jaguar Sovereign
1992 Mazda Miata
wlee is offline   Reply With Quote
