Old 12-11-2008, 07:13 PM   #1
Pillow
Pillow's Avatar
Stiffer springs for a C-10?
I am wondering if there is a stiffer spring kit available for the C-10 trucks with the trailing arm rearends.
They ride like a Cadillac, but are a bit soft for a work beast.
I *think* the C-20s came with a leaf spring rear?
I am planning on buying another C-10 or C-20 for a work truck but need something closer to a 3/4 ton capacity. Just wondering if the C-10 can be beefed up.
Also I am exploring the possibility of putting a 6.2 diesel in it, that is a different issue at the moment, but it is heavier than a SBC and needs heavier springs as well.
Thanks!!!
'71 C-10 with 5.3 LS2 cam & NWC T5 - Patina King!
'83 Jeep Cherokee w 5.3 LS9 cam & SM465 NP208 swap in progress
'92 Volvo 960 wagon w 5.3 LS7 cam & WC T5 swap in progress
'79 Porsche 911 SC
'48 Spartan Mansion 30' travel trailer
'10 Porsche Cayenne S - Daily
Pillow is offline   Reply With Quote
Old 12-11-2008, 07:39 PM   #2
caminokid
Chevy nut
caminokid's Avatar
Re: Stiffer springs for a C-10?
My C-20 has coils. I am using them on my C-10. I just want the rake to my truck.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 12-11-2008, 09:20 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You can put 3/4 ton coils in a 1/2 ton with zero mods. The frames are 99% the same between a 1/2 ton and a 3/4 ton, but the rear axle and brakes are the main things upgraded on a 3/4 ton.
Old 12-11-2008, 10:46 PM   #4
Pillow
Pillow's Avatar
Awesome guys! Thanks for the info.
I guess a bone head question there after all. I have just never had the opportunity to look under a c-20
I will keep you all updated on my search.
'79 Porsche 911 SC
Old 12-12-2008, 12:00 AM   #5
caminokid
Chevy nut
caminokid's Avatar
Not a bone head question. You dont know unless you have had these or have seen one up close like most of us here have. This is why this board is here. At 41 I still dont know everything about these trucks. Never done a 6 to 8 conversion before...so I asked. Done plenty of car 6 to 8's but never the 67 to 72 Chevy truck before. So dont ever think you aksing something bone head. We are here to help!
Old 12-12-2008, 12:10 AM   #6
Longhorn Man
yep...I agree with camino (never knew you were so old man!)
And you can't assume with these rigs either, they'll throw you for a loop... esp if you are in a car frame of mind.
Old 12-12-2008, 12:11 AM   #7
caminokid
Chevy nut
caminokid's Avatar
so true...or even 73 to 87 Chevy truck kind of mind. These trucks are in a class all their own!
Old 12-12-2008, 01:15 AM   #8
ERASER5
ERASER5's Avatar
As far as upgrading the C-10 springs, there are air bag helper springs. When have no load, let out the air. When you haul a load, air it up.
The C-20 springs will work just fine, but the ride will be harsher, if that matters at all.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 12-12-2008, 02:09 AM   #9
Gray Ghost
Gray Ghost's Avatar
I put panel truck springs [3/4 ton] on mine and it's a workhorse. Also have the helpers on it....it will carry a ton easily and rides fairly smooth.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 12-12-2008, 12:36 PM   #10
OrangeCrush1970
OrangeCrush1970's Avatar
My truck (1/2 ton) came with heavy duty coils (3/4 ton) from the factory and while Im sure they're well broken in, the ride is very good, not harsh at all...
Rottenwood Garage
1970...71...72 C1500 aka Orange aka Sideshow Bob
540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600
2 Tons of Fun
OrangeCrush1970 is offline   Reply With Quote
Old 12-12-2008, 03:37 PM   #11
steelhorse
steelhorse's Avatar
You can also add coil over shocks.
steelhorse is offline   Reply With Quote
Old 12-12-2008, 04:45 PM   #12
Stock72c10
classic=of recognized value
Stock72c10's Avatar
Check out the ones in this thread. Many people say they work pretty well. I only had one on my truck as the other one broke off but it is nice because they ride normal until you load the truck up then the helpers kick in. They are cheap too, but that may be slightly due to build quality (the U-Bolts broke on mine when removing). http://67-72chevytrucks.com/vboard/s...d.php?t=311829
Stock72c10 is offline   Reply With Quote
Old 12-12-2008, 09:47 PM   #13
Pillow
Pillow's Avatar
I believe the rear control arms are the key to the wonderful ride in these trucks. Why they went away in the later generations of trucks is beyond me.
I have been using the '71 for a worker for the last few weeks to try it out and it has performed very well. Mostly trying it due to gas being so much more than diesel.
More silly questions to come
'79 Porsche 911 SC
Old 12-12-2008, 09:59 PM   #14
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
That's a bad idea. The shock mounts were never intended for the added stress of supporting the load. Lots of lower shock mounts have ripped out even with stock shocks. Add the stress of a coil over and you're really asking for lower shock mount failure.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-12-2008, 10:05 PM   #15
Gray Ghost
Gray Ghost's Avatar
I completely agree....I will never own another leaf spring truck. I call them the 'world's largest traction bars'!
Kelly
Old 12-13-2008, 12:47 AM   #16
caminokid
Chevy nut
caminokid's Avatar
The bad thing about coils is wheel hop. I do like the fact that coils on the back are easier to change...but leaf will hold a better load.
Old 12-13-2008, 12:52 AM   #17
Gray Ghost
Gray Ghost's Avatar
Wheel hop? I guess mine's set up better than stock....never had that happen.
As for load, that may be true with stock 1/2 tons but I have 3/4 ton coils and helpers so that's a non -issue.
Kelly
Old 12-13-2008, 01:00 AM   #18
caminokid
Chevy nut
caminokid's Avatar
I am using the 3/4 springs and helpers on the 1/2 in the garge. I am looking for a little rake on mine. Giving that jacked up hot rod look.
Old 12-13-2008, 01:43 AM   #19
Gray Ghost
Gray Ghost's Avatar
I love a little rake for sure but mine doesn't have much since I haul lumber and such most of the time...
On the rare occasion it's empty, it has a bit of rake to it. Always liked that...
Kelly
Old 12-13-2008, 04:09 AM   #20
nicolas72gmc
nicolas72gmc's Avatar
Does anyone make bag set-up for leafs? I dont know where they would mount, but it sounds like a good idea. Sucks when I change my leafs out to drop leafs, i will have to remove the overload leafs.
Nick
"Everyone has a plan, 'till they get punched in the mouth".........Mike Tyson
1968, GMC, SWB, Project
1972, GMC, LWB, Daily Driver, 383, headers, 2.5"/3" exhaust, 200r4, 3.5/5 ECE components.
1972, C/10, LWB, 350 vortec, th350
nicolas72gmc is offline   Reply With Quote
Old 12-13-2008, 05:22 AM   #21
bad6772
Official Site Guitar Shredder
bad6772's Avatar
There is a ( Air over leaf ) Kit That Air Ride has......Not sure on cost....It mounts the the leaf and to the frame....I think its a all (bolt) on type of deal.......
bad6772 is offline   Reply With Quote
Old 12-13-2008, 06:19 AM   #22
El Jay
Gone to greener pastures
Yup.
Shock eggsorbers are for controlling rebound, not carrying weight.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 12-13-2008, 08:23 AM   #23
67slammer
67slammer's Avatar
did you ever think about putting on the auxillary spring set? they were a option on these trucks.
67slammer is offline   Reply With Quote
Old 12-13-2008, 10:55 AM   #24
WorkinLonghorn
WorkinLonghorn's Avatar
Then I would suggest getting a C-20 which IS a "3/4 ton" truck. Actually a GMC 2500 would be even better as you will have more headlights and a colored dash.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 12-13-2008, 02:24 PM   #25
Aarons72s
My green truck has 3/4ton hd springs in it. It was originally a slide in camper truck. Not the smoothiest ride when empty but when you load her up she rides smooth as couldbe. As for the coil over shocks, deffinently dont use them. As they said the mounts were not made to take the extra weight. I had them in my orange truck and they cracked the lower shock mounts. The orange truck had them due to it was also a slide in camper truck. But instead of changing the springs they just added the coilover shocks.
Aarons72s is offline   Reply With Quote
