Old 12-13-2008, 01:01 AM   #1
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
Pinion angle
Sup folks?
I have a '68 long box W/ 1" spring and 2 1/2" drop spindles in front and a 4" spring w/ a 3/4" block in rear. I don't like the block I cant find a true 5" spring.
So my ? is what pinion angle shim is the best for my app. If any one has played around w/ this Please any tips would be great. I believe they make a 1-6
68 C-10 KID is offline   Reply With Quote
Old 12-13-2008, 01:12 AM   #2
5150.4.67
Re: Pinion angle
http://www.iedls.com/IEDL_PTS_LGL_091008_Secure.pdf
Check out this site. You will have to do some measuring if no one with your same setup replies. Hope this helps.
Jay
5150.4.67 is offline   Reply With Quote
Old 12-13-2008, 01:15 AM   #3
68 C-10 KID
Mean Green
Re: Pinion angle
Jay
Very nice thank you.
Old 12-13-2008, 01:16 AM   #4
5150.4.67
Re: Pinion angle
BTW, are those Hoosier slicks hidin' in the wells?
Old 12-13-2008, 01:18 AM   #5
68 C-10 KID
Mean Green
Re: Pinion angle
Hellz to the yeah! If a guy wants to play w/ 600 hp on the street its the safe way to do it.
Old 12-13-2008, 01:26 AM   #6
5150.4.67
Re: Pinion angle
I can almost smell the molten rubber and smoke!
Jay
Old 12-13-2008, 01:46 AM   #7
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Pinion angle
Originally Posted by 68 C-10 KID View Post
Sup folks?
Have you checked the Early Classic 5" springs. I bought their kit with 2 1/2" drop spindles and 1" springs front and 5" springs rear. I haven't gotten everything installed but I would trust ECE to give you what they advertise. They also keep the load rating so you can use your truck as a truck, if you needed to.
As for pinion angle, this would be good into as I am swapping in a new rear end and need to weld the axle pads on. Anyone know what the stock angle is?
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 12-13-2008, 01:48 AM   #8
cdowns
cdowns's Avatar
Re: Pinion angle
you'd think somebody with 600hp could measure the pinion angle to get it precise
Old 12-13-2008, 01:50 AM   #9
5150.4.67
Re: Pinion angle
I believe 3 degrees.
Do you need the axle pads for trailing arm rear end? I have a brand new set I'm not using from CPP.
Jay
Old 12-13-2008, 01:52 AM   #10
68 C-10 KID
Mean Green
Re: Pinion angle
Sorry bro I'm no chassis guy or a drive line tech. I can build a sbc to blow your mind.
Old 12-13-2008, 01:54 AM   #11
68 C-10 KID
Mean Green
Re: Pinion angle
just in case you want to make fun of that too. here is the proof.
Old 12-13-2008, 01:54 AM   #12
chevy_mike
chevy_mike's Avatar
Re: Pinion angle
Jay
Thanks for that info. I was thinking 3 degrees as this is very common for most Chevy's. As for axle pads, thanks but already have some from ECE. Just waiting to get the rear end installed.
Old 12-13-2008, 02:03 AM   #13
68 C-10 KID
Mean Green
Re: Pinion angle
Had to re size
Old 12-13-2008, 11:37 AM   #14
c10crazy
Like a Rock!
c10crazy's Avatar
Re: Pinion angle
Wow! - would love to see the specs of your motor
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 12-13-2008, 12:43 PM   #15
Scottshotrods
Re: Pinion angle
we set are pinion angles at our shop
at 3 degrees
Justin
www.scottshotrods.com
Scottshotrods is offline   Reply With Quote
Old 12-13-2008, 07:09 PM   #16
68 C-10 KID
Mean Green
Re: Pinion angle
.030 bore
flat top JE
Scat crank and 6" rods
Splayed into 4 bolt main.
isky .640 @ 260 inst. @ a 106.5 deg
Comp cams wet belt.
jesel shaft mount 1.6 rockers
AFR 227cc Brodix HV 1000 intake and a 950 cfm Holley
Old 12-13-2008, 07:10 PM   #17
68 C-10 KID
Mean Green
Re: Pinion angle
at 3 degrees
Justin
Thank you. I just need to crawl under the pig with a deg finder then do the math.
