Old 01-06-2009, 06:46 PM   #1
kookykrispy
The Early Chevy Van Man
Please help me fix my factory 4 season air conditioning
I searched for this, but didn't find anything. Anyways, my truck has the factory 4 season A/C. It doesn't work... the previous owner somehow 'rigged' the heater controls so that warm air always blows out the defroster... no matter what you set the levers at.
The hub of the compressor seems to be stuck. The fan belt is gone. There is a hardline missing that goes between the receiver/dryer and the condensor.
Where do I begin with this? I have NEVER worked on A/C before, but I want to learn how to fix this.
Hopefully someone can help. If there is already a thread on this, and somebody can please post the link, that would be very helpful.
64 Chevy Van
65 GMC Handi-Van
99 2500 silverado 4x4 ext cab
kookykrispy is offline   Reply With Quote
Old 01-06-2009, 08:21 PM   #2
JimKshortstep4x4
Re: Please help me fix my factory 4 season air conditioning
My suggestion would be to buy the Service Manual for your truck as it has a great section on AC's.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 01-06-2009, 08:47 PM   #3
kookykrispy
I have it in hand actually... its just overwhelming. I'm not sure where to begin or how to troubleshoot the system... also what all is involved with changing to r-134?
64 Chevy Van
65 GMC Handi-Van
Old 01-06-2009, 09:48 PM   #4
haysonj
haysonj's Avatar
It really isn't that hard but it can be expensive. Your first problem is the compressor and if it has to be replaced you should go with one that is set up for 134A If you do this then you have to change all your lines because the newer fittings will be differant. If you just have your compressor repaired You can buy a conversion kit to change to the 134A You need a new dryer for 134A You will also need someone to vac check the system and install the 134A as far as the controls it is just time to check the cables behind the dash control. There is also a door in the diversion box that goes bad and will probably have to buy a new box. I rebuilt my entire system and bought a new compressor and it cost almost $1000 so you might look at an after market kit.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
